Bison Trailers Starting on Fire
Jump to page : 1 2
Last activity 2009-02-27 1:19 PM
46 replies, 16971 views
gabz
Posted 2009-02-12 12:37 PM (#99369 - in reply to #98851)
Subject: RE: Bison Trailers Starting on Fire
1000100100100252525
The original post mentioned 2 types of fires.  One from wiring in the electric jack (needs an inline fuse to fix) and the other in regard to refrigs.
Okay. It's clear there is a recall on the fridges, it's been in many, many magazines.
But no one has responded about the jack wiring. hmmmm???
I'm impartial. I have a Titan. No electrical except for brakes and lights.
DD_TrailerMan
Reg. Jul 2008
Posted 2009-02-12 12:50 PM (#99371 - in reply to #99369)
All electric jacks should have a breaker, ours come with the breaker already installed.  Also, there should be a breaker (we use 80 amp) coming off the 12V.
mseyle
Reg. Mar 2007
Posted 2009-02-12 1:57 PM (#99383 - in reply to #98851)
I own a 2006 Bison and did have the recall on the frige and it was repaired by a RV dealer.  I also have an electric jack and it does have a breaker between the battery and the jack motor it came that way from the factory.
Posted 2009-02-12 3:21 PM (#99387 - in reply to #98851)
I don't have a Bison trailer. But I do have a trailer that has a AM series "Equalizer System" hydraulic jack.... I traced the #4 gauge wire from the solenoid all the way back to the battery, there's no fuse or breaker. So if the solenoid or the wire between it and the battery goes to ground, then we to, will have a fire. According to the jack mfg., a fuse is not required, they leave it up to the trailer mfg.'s discretion...... This is what I found in the "Equalizer System" installation instructions.
Battery Connections for MTE Style Pump with Manual Override
Battery Lead (+12volts): Attach a #4 gauge wire between the positive 12-volt terminal on the battery and the
large post on the solenoid opposite the black motor wire on the solenoid. Do not fuse this lead.
Pump Ground (-12volts): Attach a #4 gauge wire between the negative 12-volt terminal on the battery and the
ground stud located directly in front of the motor.
 http://equalizersystems.com/documents/Single_Leg_AM_CM_20,_24_and_30.pdf
Edited by retento 2009-02-12 3:28 PM
crowleysridgegirl
Reg. Apr 2005
Posted 2009-02-12 9:06 PM (#99399 - in reply to #99308)
2000500100
Paul C,that's pretty close!
gabz
Posted 2009-02-13 4:52 PM (#99432 - in reply to #98851)
1000100100100252525
Thanks Retento for doing some investigating.
So... did you fix your's? (will you?)
Posted 2009-02-13 5:13 PM (#99433 - in reply to #99432)
Originally written by gabz on 2009-02-13 5:52 PM
Pump motor calls for 65 amps. I'm going to install a 80 amp fuse at the battery.... It is disconnected at the battery at this time, until I round up a couple of 80 amp fuses and a fuse holder.
luv2tallyho
Reg. Apr 2008
Posted 2009-02-17 8:27 AM (#99610 - in reply to #99369)
OMG!!!!  I have a Bison....why is it going to catch on fire...I logged on today to put up a post asking the question  "why does my trailer have a burning smell"  Everytime I take it somewhere and my battery disonnect is pulled out, in the on position, it smells like something is "hot" inside the LQ  if I push it in and turn it off the smell goes away.  It only gets that way when I'm hauling.  When the trailer is home and is plugged up it's fine.
I had no idea about the recall on the fridge....ya'll need to fill me in!!!!  Show season is starting and my daughter and I will be on the road a lot.  I don't want my trailer to burn up!!!  Help!
Posted 2009-02-17 8:59 AM (#99614 - in reply to #98851)
Here's some info on the Dometic Recall Information...
http://www.usrecallnews.com/2008/08/nhtsa-1777.html
http://www2.dometicusa.com/recall.php
http://rv.net/forum/index.cfm/fuseaction/thread/tid/18592913.cfm
 http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/18592867.cfm
Edited by retento 2009-02-17 9:02 AM
brushycreekranch
Reg. Jun 2006
Posted 2009-02-17 9:29 AM (#99617 - in reply to #98851)
500100100100100
tally ho.......maybe you should also contact the dealer that sold you the trailer and let them know about the burning smell.
BlazingCreekBar
Reg. Nov 2008
Posted 2009-02-17 9:59 AM (#99621 - in reply to #98851)
Just had my fridge corrected yesterday. The RV dealer did a great job! Took almost 1.5 hours. There was a stud in the way so they pulled my fridge. Everything worked out fine.
Glad I read this one. We leave our Pup behind in the rig and the rig is connected to our truck. That would be a bad day!
billmrmi
Reg. May 2008
Posted 2009-02-21 6:23 PM (#99842 - in reply to #98851)
Just a few thoughts on the last few posts:We have not heard multiple people tell us other brands are having problems catching on fire, it is only Bison, that is why I posted what I did. If people were calling up telling us "BRAND X" was catching in fire in numbers, I would report that for safety reasons.The American Spirit trailers with RC conversions are fairly good trailers. We had very little problems with those trailers. I know that at the end of our relationship American Spirit was starting to build their own LQs, and we have no experience with them. I spoke with the owner a few weeks back and he said if we wanted to start working with them again, they would be happy to have us back. The employee at American Spirit who canceled us as a dealer is no longer with American Spirit. Seeing as we do not stock or sell a competitive brand to Bison, I am not sure what financial gain people are thinking I am getting from this post. If anyone would like to let me know what that gain is, I would be happy to address it.To retento, I suggest you use the rated fuse per the manufacturer's specification. Using a higher rated amp fuse somewhat defeats the purpose of using the fuse at all.
Posted 2009-02-21 7:26 PM (#99847 - in reply to #99842)
Originally written by billmrmi on 2009-02-21 7:23 PM
 Mr. Bill, At the moment... It has no fuse, Equalizer don't even suggest that a fuse be used. They say "Do not fuse this lead". It takes 65 amps to run the pump.... Got to have a little margin or else it will blow a fuse everytime you jack the trailer up. That's the reason I'm using the 80 amp fuse, rather than a 65 amp, or as Equalizer suggest.... No fuse.
Posted 2009-02-21 9:15 PM (#99853 - in reply to #98851)
Retento,
What about a slow blow fuse or breaker similar to ones used on air conditioners and other motors with a high initial starting draw? You would then be protecting your running circuit, with the proper amperage needed for a continuous operation.
billmrmi
Reg. May 2008
Posted 2009-02-21 11:04 PM (#99856 - in reply to #98851)
Sorry, I thought you were using a 80 amp where it said to use a 65.
Whisper
Reg. Jul 2008
Posted 2009-02-22 6:28 AM (#99860 - in reply to #98851)
"The employee at American Spirit who canceled us as a dealer is no longer with American Spirit". At least you have confirmed the rumor. And an employee is the "tool" of the company. Bottom line, no matter who called or sent a letter, American Spirit Manufacturing dropped you as a dealer.
HWBar
Reg. Nov 2005
Posted 2009-02-22 6:39 AM (#99861 - in reply to #98851)
1000100100252525
There are only a few reasons that a manufacturer would drop a dealer, one would be you aren't selling enough of their product, another would be that you could have a public image problem. Getting on a public horse trailer forum and bashing any brand of trailer would cause the second. I sell equipment for a living, I have always had great sucess in selling the features and benefits of my product, not trying to berate the competitors. So as you continue to spout off in a public forum about the very products that you sell. I would just say that the thousands of people that visit this site a day, good chance that some of those are manufacturers or their reps. JMHO
Edited by HWBar 2009-02-22 6:40 AM
whinneyman
Reg. Oct 2007
Posted 2009-02-22 10:51 AM (#99883 - in reply to #98851)
The #4 wire will handle up to 200 amps at 20 feet or less total lengthof circuit,supply and return. The usual rule of thumb for fuse sizing is 150% to 200% of current draw of the device. The wire size and 80 amp fuse for the jack are on the very safe side in my opinion.
Whinneyman
billmrmi
Reg. May 2008
Posted 2009-02-23 2:33 PM (#100004 - in reply to #98851)
HWBar,
When it comes to people's safety, I will continue to "spout" off. If it tarnishes my image, then so be it. It appears that several people have read this post and have benefited from it. I am sure many others that did not post back also received some benefit.
billmrmi
Reg. May 2008
Posted 2009-02-26 2:19 PM (#100227 - in reply to #98851)
Spoke with the owner of American Spirit this week. They provided us with quotes for a trailer, so I guess the action of the "tool" has been overridden.
HWBar
Reg. Nov 2005
Posted 2009-02-26 2:42 PM (#100231 - in reply to #100227)
1000100100252525
Originally written by billmrmi on 2009-02-26 2:19 PM
I get a feeling if I called him, I could get a trailer quoted also. They have been selling them direct on E-bay you know?
So I'm not sure that this would be a feather in your dealer hat if you know what I mean.
Elly
Reg. Jul 2008
Posted 2009-02-27 1:19 PM (#100307 - in reply to #98851)
Hwbar hit it on the nose. I think they would sell or quote a trailer to any dealer or directly to any individual that has the cash to buy it. So being proud to once again (supposedly) represent a manufacturer that chooses to do business that way, would not be something that I would be bragging about.
Jump to page : 1 2
