"service trailer Brake system" message on the DIC 2008 GMC SIerra
Last activity 2011-10-05 12:07 AM
4 replies, 27503 views
ncsuacd
Reg. Sep 2007
Posted 2009-02-02 6:11 PM (#98664)
Subject: "service trailer Brake system" message on the DIC 2008 GMC SIerra
2008 GMC Sierra, 20k miles on it.
"service trailer Brake system" message came on the DIC today while on my way home from work.
I was not towing a trailer at the time.... Anyone know anything about this?
Posted 2009-02-02 7:11 PM (#98667 - in reply to #98664)
Subject: RE: "service trailer Brake system" message on the DIC 2008 GMC SIerra
Here's some previous postings about similar problems:
http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=10476
Posted 2009-02-02 7:22 PM (#98668 - in reply to #98664)
Check your owners manual.... Then check for water or corrosion inside the trailer plug on the rear of the truck. Check for a blown fuse. Been in any salt lately? May be something on the same order as the oil change reminder.... Mine comes on every 8000 miles.... Check the manual for a "reset" procedure.
 http://www.dieselplace.com/forum/showthread.php?t=213437
Edited by retento 2009-02-02 7:24 PM
randemtam
Reg. Jun 2007
Posted 2009-02-04 1:04 PM (#98795 - in reply to #98664)
10010010010025
Did you happen to have another plug installed? This happened to me every time it rained when I had an extra plug installed for the GN. I wasn't towing when it happened either. I took it back to the installer and he taped it up more or something (can't remember exactly) and it hasn't happened since. I have an 08 Chevy 3500. He made the comment that Ford just recommends soldering, period, to keep it from happening. Apparently, it's a somewhat common problem....
FWIW
Posted 2011-10-05 12:07 AM (#138062 - in reply to #98664)
Further information:Some owners of a 2007-08 Silverado or Sierra with RPO JL1 may comment of a Service Trailer Brake System message displayed on the DIC. DTCs C1112 and/or C1114 will be set in the Trailer Brake Control Module (TBCM).TIP: This concern may occur with or without a trailer connected to the vehicle.Updated TBCM calibrations have been released in TIS2Web to improve TBCM diagnostics for a high resistance short to voltage concern. The Tech 2 can be used to monitor the TBCM Relay Feedback Signal parameter located under Chassis/Trailer Brake Control Module/Data Display to help determine if there is a short to voltage.The normal voltage reading is between 3.2-4.1 volts. If the voltage is higher, the updated calibration will help. If the voltage is lower, the updated calibration should still be installed. However, additional diagnostics may be needed to correct the concern.TIP: Refer to the latest version of PIT4595D and appropriate SI diagnostics for additional help.
