trailer wire adapter?
Last activity 2009-01-28 8:26 AM
13 replies, 5981 views
Rosie Wilson
Reg. Jan 2009
Posted 2009-01-27 8:28 AM (#98305)
Subject: trailer wire adapter?
I have purchased a Brenderup which has a 7-Point wire receiver (i.e. female). I need to connect it to the 4-flat on my truck but I cannot find an adapter with a 7-point male on the trailer end. I would like to hear from any other member of the forum who has made this connection. Thanks.
Posted 2009-01-27 9:15 AM (#98311 - in reply to #98305)
Subject: RE: trailer wire adapter?
You may have to make up your own pig tail adapter, using a male and female plug and a length of multiple wire power cord. Your four pin plug only has brake, running lights, turn indicators and a ground wire. Not all the 7 pins in you trailer are being used. You will have to determine which ones are, and what their functions include. You will not have a hot wire for interior lights, back up lights, nor a braking circuit coming from your tow vehicle.
Edited by gard 2009-01-27 9:32 AM
flyinghfarm
Posted 2009-01-27 10:07 AM (#98313 - in reply to #98305)
1000100100
You will need six of those connections if you have a brake control on your tow rig....if not, I'd get one... then you will still need a wire to have a 6 male on one end, and a 7 male on the other to attach to the trailer.  This seems unusual to me.
Posted 2009-01-27 10:37 AM (#98318 - in reply to #98313)
Originally written by flyinghfarm on 2009-01-27 11:07 AM
Brenderup trailers use an inertia braking system, not electrically controlled by the towing vehicle
chadsalt
Posted 2009-01-27 12:37 PM (#98329 - in reply to #98305)
1000100100100100
If I understand correctly, this should work;  http://www.etrailer.com/pc-A~30717.htm
But I would match the trailer plug to the truck, or wire the truck for a standard 7 blade rv socket.  Im not a big fan of adapters other than for temporary use.
What are you driving?  There are a lot of plug and play parts available.
Or for that matter change the whole thing out for an EZ Connector..............
Edited by chadsalt 2009-01-27 12:50 PM
Posted 2009-01-27 2:45 PM (#98336 - in reply to #98305)
Since the Brenderup does not require a brake control wire, just replace the trailer connector with a flat four plug.
Edited by hosspuller 2009-01-27 2:47 PM
Posted 2009-01-27 3:43 PM (#98339 - in reply to #98336)
Originally written by hosspuller on 2009-01-27 3:45 PM
Good point !!! Simple and inexpensive. That would be the way to proceed for about $2.
Tresvolte
Reg. Feb 2008
Posted 2009-01-27 4:46 PM (#98342 - in reply to #98305)
Does a Brenderup not have a seperate hot wire?
horsey1
Reg. Dec 2004
Posted 2009-01-27 4:57 PM (#98343 - in reply to #98305)
What does it do to lock the surge brakes out during reverse? Most boats have a solenoid triggered off of the reverse lights circuit.
BlazingCreekBar
Reg. Nov 2008
Posted 2009-01-27 5:53 PM (#98346 - in reply to #98305)
Wally Mart sells converters check in the towing section.  I convert my four plug poop wagon up to the seven pin on the truck.  I have one on my bench that goes the other way.  Easiest thing to do so you don't have to change any factory set ups.
BlazingCreekBar
Reg. Nov 2008
Posted 2009-01-27 5:56 PM (#98347 - in reply to #98305)
Just found this write up...
The inertia brake system doesn't need a trailer brake controller.  These are the standard brake system in Europe. The brakes are activated by a surge type coupler, but instead of using hydraulics like a boat trailer, the coupler pulls a rod attached to all 4 wheels by cable. This is speed and load sensitive. The brake drums and bearings are maintenance free. Twin leading shoes in each drum, are bi-directional,  when you back up there is a 3% drag factor. The parking brake will turn the brake cam over center and lock the wheels from turning in either direction. Having a parking brake is great. there are none of those brake magnates in the wheels. Great braking, it all seems to simple, but it works. No brake magnates, no break away battery, no trailer brake controller, no sway, nobody else does all that.
Posted 2009-01-27 6:17 PM (#98349 - in reply to #98305)
Correctomundo... BlazingCreekBar, all mechanical, no fluid, no electricity, just cables, chains, rods and a spring or two, keeping it simple.
http://horsetrailerworld.com/Home/contribute/Homepage/Mrtruckbrenderup/mrtruck.asp
http://www.brenderuprealtrailers.com/news.htm
Edited by retento 2009-01-27 6:20 PM
BlazingCreekBar
Reg. Nov 2008
Posted 2009-01-27 6:22 PM (#98350 - in reply to #98305)
Very cool rigs.
A friend of ours has one attached to her Hybrid SUV.  I like the trailer.  I worry sometimes about it and the tow vehicle not being heavy enough to compensate an issue.  But if your careful you will stay safe.
Rosie Wilson
Reg. Jan 2009
Posted 2009-01-28 8:26 AM (#98385 - in reply to #98305)
thanks to all who have contributed to this thread. I have decided to retrofit a 7-pole wire to the truck.
