HELP! DIY insulation on a living quarters
Last activity 2009-01-26 10:30 AM
4 replies, 7544 views
jennig25
Posted 2009-01-25 5:54 PM (#98210)
Subject: HELP! DIY insulation on a living quarters
Help please, my husban and I have a new cimmarron 4 horse gooseneck that we are putting a small weekender into. We are having trouble figuring out what R value insulation is best to use. we travel in to many different climates from califonia to texas. Any seguestions would be greatly appreciated.
Posted 2009-01-25 6:07 PM (#98212 - in reply to #98210)
Subject: RE: HELP! DIY insulation on a living quarters
Check this out, it may answer some of your questions... http://todd.redwrench.com/index.htm
willie 77
Reg. Feb 2007
Posted 2009-01-26 7:42 AM (#98239 - in reply to #98210)
on mine i used 1" blue styrofoam,i think it had a r-value of 5. also after i ran my furring strips i cut 3/4 " styrofoam to fit in between the strips i dont think  you can have to much insulation....You can also look into the bubble wrap insulation not sure of the r-value
smoothride
Reg. Mar 2005
Posted 2009-01-26 7:47 AM (#98240 - in reply to #98210)
I have been in the conversion shops and have seen them install a kraft faced fiberglass batt that has a R-8 value. Appeared to be 1 1/2" thick
racesarabhorses
Reg. Oct 2005
Posted 2009-01-26 10:30 AM (#98251 - in reply to #98210)
I have heard that foamboard, with bubblewrap covering it and the structural braces, works very well.  Also can use fiberglass or cotton insulation batts between braces, covering all with bubblewrap.
Mike
