strapping fresh water tank
Last activity 2009-01-19 8:42 AM
3 replies, 4191 views
Horsemen
Reg. Oct 2008
Posted 2009-01-17 5:10 PM (#97676)
Subject: strapping fresh water tank
I am putting my fresh water tank under the seat in front of the sleeper and was wondering what you al are doing to strap it down to keep it in place, Thanks
Posted 2009-01-18 9:29 PM (#97738 - in reply to #97676)
Subject: RE: strapping fresh water tank
Boat owners that use outboard motors, frequently incorporate removable fuel tanks. On the floor located at each side of the tank, is an elongated "C" shaped cleat, made of nylon or stainless steel. These are screwed into the flooring.
An adjustable strap is located between them, and looped over the top of the tank. When the strap is tightened and secured, the tank is as well. When the strap is loosened, the tank can be removed for cleaning or refueling. One or more of these straps could be used to secure a water tank.
Horsemen
Reg. Oct 2008
Posted 2009-01-19 4:00 AM (#97746 - in reply to #97738)
Thanks Gard, I didn't even think about that, I think I must of had mind block because I have been in the marine industry for over 30 years, the paint must be getting to me, Thanks again
Edited by Horsemen 2009-01-19 4:03 AM
Posted 2009-01-19 8:42 AM (#97758 - in reply to #97676)
Another way to secure the tank, would be to mount eye bolts into the flooring on each side of the tank, and use one of the light duty, ratcheting load straps between them to secure things.
Outside, the strap rapidly deteriorates with UV exposure, but in an enclosed space, it shouldn't be a problem.
You're welcome
BOL  Gard
Edited by gard 2009-01-19 8:44 AM
