Input on Sundowner Valuelite 727-2003
Last activity 2011-03-17 8:43 AM
21 replies, 30749 views
martinme
Reg. Oct 2008
Posted 2009-01-11 7:57 AM (#97289)
Subject: Input on Sundowner Valuelite 727-2003
 Anyone have any input on a Valuelite 727?  I'm considering buying one and just looking for any pros or cons that I might watch for.  It is a 2003 and from the pictures looks absolutely spotless.  Any information for me?
HWBar
Reg. Nov 2005
Posted 2009-01-11 8:17 AM (#97290 - in reply to #97289)
Subject: RE: Input on Sundowner Valuelite 727-2003
1000100100252525
Sundowner has had a warranty problem with the 727 line of trailers, they are a steel frame trailer and Sundowner used a product similar to Line-X to coat the bottom of these trailers, they call it Suncoat, well it doesn't hold up and they have had alot of corrosion issues. To the point that Sundoner had been replaceing complete frame rails under trailers. I am not here to bash any brand, these are facts that can be read about by doing a search on this website or google either one. So unless you can get it inspected by someone that understands this problem, you might want to look for an all aluminum trailer.
hogtownboss
Posted 2009-01-11 10:09 AM (#97300 - in reply to #97289)
10001001001002525
We just bought a 04 Sundowner 8010 Signature series 727 and it is in great shape. But we are in North Texas! Look under the rear rump side of the trailer, this is the first place to start going bad and is caused from lack of cleaning out the inside of the trailer.!
boobearzoo
Reg. Jan 2011
Posted 2011-01-21 6:56 PM (#129133 - in reply to #97289)
I have one ( 2001) and i LOVE it no problems at all , every horse LOVES to get on it and trailers like a DREAM
ace_014
Reg. Feb 2009
Posted 2011-01-24 7:21 AM (#129193 - in reply to #97289)
 I have a 2006 and have had no problems with it. It was a stock combo that I bought new I have since had it closed in and a LQ installed.
kvanderv
Reg. Mar 2011
Posted 2011-03-15 10:12 PM (#131695 - in reply to #97289)
Subject: RE: Input on Sundowner Valuelite 2001
I am looking at a 2001 Valuelite and the trailer is in excellent shape, however the person selling it said that it is fine now bu will have to have the floor fixed down the road.  Hmmm, what to do?  Do I stick with an all aluminum trailer or take the risk as these all have a steel frame correct?  Worried as the trailer is hours away so I cannot just fun and see it.  What is Sundowner doing for people like me that buy a trailer that this happens to without a warranty?
jim bob
Reg. Jan 2008
Posted 2011-03-16 9:43 AM (#131709 - in reply to #97289)
kvanderv - The trailer is a 2001 your looking at.  It has no warranty left in it.  Any brand of trailer that is of that age wouldn't have any warranty left.  Your buying a used 10 year old trailer.  Just inspect it closely before purchase.
Any Sundowner model would have an aluminum frame if built after Jan.1, 2008.
whitewood
Reg. Jun 2009
Posted 2011-03-16 9:48 AM (#131711 - in reply to #97289)
what happens to the suncoat is it does not fall off, it just lets loose from the steel in places. If it came off it would be less of a problem. In areas where salt is common, the wet salt is trapped between the steel and the suncoat and eats up the steel in that location. The suncoat stayed on some trailers much better than others. If they were used hard on rock roads, it tough on the suncoat.
kvanderv
Reg. Mar 2011
Posted 2011-03-16 9:57 AM (#131712 - in reply to #97289)
Thank you both for the feed back, I do know there is no warranty left and to inspect it well but if this is a problem with these trailers then I will stay clear. I love Sundowner trailers and would love to own one and this one is on my price range but not if I will be spending a ton of money to replace the floor. What do I need to look for specifically with this model to know? I have a friend that is going to look at it for me, as it is a 700 mile drive for me, prior to me making a decision. Or should I just by an all aluminum Exiss for the same price (though without some of the bells and whistles that the Sundowner has)?
horsey1
Reg. Dec 2004
Posted 2011-03-16 10:42 AM (#131714 - in reply to #97289)
Just for the record- Suncoating is the name Sundowner uses for the spray in bedliner product that is on the sidewalls of the stock area and sometimes under the neck. The frames were powder coated, a process very popular in many industries as an alternative to paint. And on later model units, the underneath had a regular automotive undercoating applied- but there was never Suncoating underneath a Sundowner trailer.
whitewood
Reg. Jun 2009
Posted 2011-03-16 11:02 AM (#131715 - in reply to #97289)
just for the record. There is suncoat on the steel frame under the trailer.
horsey1
Reg. Dec 2004
Posted 2011-03-16 2:12 PM (#131719 - in reply to #131715)
I respectfully beg to differ, and will leave it at that.
kvanderv
Reg. Mar 2011
Posted 2011-03-16 2:23 PM (#131720 - in reply to #97289)
Ok, I really wanted to know if I should stay away from this particular model or is this issue occruring because people are not caring properly for their trailers? Sundowner said they will replace the floor for cost at their main facility for $2500, why would they offer if it is not a design flaw and also, would that cause structure issues to break original frame welds and patch a new floor in? I know this is a used trailer and if any trailer is not properly cared for will have problems...I need to know if I should just stick with an all aluminum or is this trailer safe if the floor is in tack? I also hear all aluminums have strengh issues and floors are replaced due to corrosion if not cared for...HELP!
Duckman
Reg. Oct 2004
Posted 2011-03-16 2:46 PM (#131721 - in reply to #97289)
There are steel runners under the ALUMINUM floor in Valuelite trailers. I don't think it would be too expensive to have more runners welded underneath if you are concerned about the floor.
kvanderv
Reg. Mar 2011
Posted 2011-03-16 2:51 PM (#131722 - in reply to #97289)
Subject: RE: Input on Sundowner Valuelite 727-2001
I know the frame is steel and the floor is aluminum...I am asking anyone that knows these trailers to tell me if this apparent issue with the powder coating on the steel frames is because people are not caring for their trailers or the trailers are poorly made and I should stay away from them.
Posted 2011-03-16 2:52 PM (#131723 - in reply to #131720)
Originally written by kvanderv on 2011-03-16 3:23 PM
You obviously have heard wrong and fail to realize how many aluminum trailers are in use privately and commercially every day. It's a fact that a ten year old aluminum trailer, properly maintained, will practically stop depreciating. How does this indicate that they have strength issues and regularly fail?
kvanderv
Reg. Mar 2011
Posted 2011-03-16 2:56 PM (#131724 - in reply to #97289)
I am not trying to start issues here with anyone...this is info I have researched regarding steel vs aluminum in trailer construction. ALL I WANT TO KNOW IS IF A VALUELITE TRAILER IS WORTH BUYING!
Duckman
Reg. Oct 2004
Posted 2011-03-16 3:22 PM (#131725 - in reply to #97289)
What is the price on the Valuelite?
horsey1
Reg. Dec 2004
Posted 2011-03-16 3:51 PM (#131726 - in reply to #97289)
Get on your hands and knees and get underneath it. There are many that are in great shape. There are some where the steel underneath has practically disappeared from the corrosion. As with any older piece (and 10+ years old is older) of equipment, each will be different. We cannot answer your question on an internet forum without more info and great pictures.
Posted 2011-03-16 4:00 PM (#131727 - in reply to #97289)
I have a 2000 Valuelite. It has the flaking paint on the undercarriage. It doesn't concern me a lot. I scraped the loose flakes and left it alone. My trailer is sheltered and the rust is surface. I am very particular about cleaning out manure and urine asap after a trip.
Unless someone sprayed Suncoat on the undercarriage after the factory, I too doubt it's Suncoat. More likely someone sprayed automotive undercoating on the frame. Anything that holds moisture to the frame is worse than bare metal.
If the price is right, buy it.
kvanderv
Reg. Mar 2011
Posted 2011-03-16 5:27 PM (#131728 - in reply to #97289)
Price is $12000
Duckman
Reg. Oct 2004
Posted 2011-03-17 8:43 AM (#131764 - in reply to #131728)
Originally written by kvanderv on 2011-03-16 5:27 PM
Price is $12000
You are in the price range that should buy you a nice all aluminum trailer(4Star, Platinum, Elite, Hart) if you have any doubt about this Sundowner.
