replacing the hold back hardware for the LQ door
Last activity 2009-01-09 3:11 PM
6 replies, 6625 views
stablemom
Reg. Jun 2007
Posted 2009-01-08 9:25 PM (#97175)
Subject: replacing the hold back hardware for the LQ door
Sorry, can't find where I had asked about this before so here it goes again. The male part of the 2 part hardware that holds your LQ door open has broken off. Don't ask me how?! Leave it to the son in college! The female part is there and is not damaged, and I have the replacement part, just need some info on the best way to do this. Told to get a pop rivet gun and stainless screws if I remember correctly. Not sure how to remove the damaged piece and are these rivet guns hard to use or expensive??
stablemom
Reg. Jun 2007
Posted 2009-01-08 9:28 PM (#97176 - in reply to #97175)
Subject: RE: replacing the hold back hardware for the LQ door
PS- Husband says zinc galvanized rivets would work. Trying to sell trailer so want to put the right kind in there.
hogtownboss
Posted 2009-01-08 10:09 PM (#97182 - in reply to #97175)
10001001001002525
Ebay has all type of hold back stuff for trailers.  I just bought a hand full of the to use the male end to mount low on the side of the trailer for bucket holders, so the horses will not kick over their feed buckets.
If the ones you have are riveted in just drill out the rivet and you can either use screws or rivets to reinstall.  A fairly good rivet gun will cost you anywhere from 5to 20 bucks.  I bought a $20. gun and use it all the time.  More than I thought I would.
Posted 2009-01-09 10:31 AM (#97195 - in reply to #97182)
Originally written by hogtownboss on 2009-01-08 11:09 PM
The low priced guns, $5 - $10, particularly the flat base type with a couple of holes near the end, work well for occasional jobs. They are limited in their capability, in rivet sizing and application. They are best used on flat, accessible, surfaces with smaller diameter and length rivets.
The better ones HTB speaks of, have various screw on replaceable tips, that are used depending on the rivet shank size. The long nipple design, allows you to pull a rivet stem, when the metal surface is not smooth or whenever the actual area around the rivet is physically restricted. The handles are usually longer, affording more mechanical advantage, and an easier pulling. They are also generally built better, and the jaws won't easily strip out when pulling larger diameter, stainless or steel rivets. This is the type of gun I would recommend, the $15 - $20 type. It's one of those tools, that when first used, you wonder how you got along without it.
If you have a large project, in which perhaps hundreds of rivets will be pulled, go directly to the pneumatic type of gun. It saves your wrists, fingers and temperament. Using the tool is no more difficult than firing a small caliber pistol.
stablemom
Reg. Jun 2007
Posted 2009-01-09 11:32 AM (#97201 - in reply to #97175)
What would be the best screws/rivets to use?? The stainless, aluminum, zinc?? thanks!
Posted 2009-01-09 2:30 PM (#97211 - in reply to #97201)
Originally written by stablemom on 2009-01-09 12:32 PM
If it's an aluminum trailer, stainless screws or aluminum rivets; if it's a steel trailer, stainless or zinc coated screws, steel rivets.
hogtownboss
Posted 2009-01-09 3:11 PM (#97213 - in reply to #97175)
10001001001002525
I would use rivets. Screws would work but I would use some thread locker before installing them just to keep them from backing out.
