How much trailer can I pull
Jump to page : 1 2
Last activity 2009-01-06 9:00 PM
31 replies, 11257 views
hogtownboss
Posted 2008-12-31 8:28 PM (#96782 - in reply to #96705)
Subject: RE: How much trailer can I pull
10001001001002525
What brand trailer are you talking about???
lindszo
Reg. Feb 2008
Posted 2009-01-01 11:26 AM (#96795 - in reply to #96782)
American Spirit.  Does the make of trailer matter? Ok Found this info on www.dodge.com/towing
2005 dodge ram 2500 pickup 2500 SLT, QUAD CAB, 4WD, 8.0 Ft Bed, 4-Speed Automatic Transmission, 5.9L High-Output Cummins Turbo Diesel Engine:
With 3.73 Axle Ratio Axle Ratio (); href="http://www-5.dodge.com/towing5/D/vehicle_2_weight_results.jsp?franchise=D&year=5&familyMarket=U&familyDivision=T&vehicleFamily=RAM_2500&model=2500+SLT&bdy_style=U%255ET%255ERAM_2500%255E5%255E2500+SLT%255EQUAD+CAB%255E4WD&bed_wheel=U%255ET%255ER#"> You Can Tow 12800 lbs
Gross Vehicle Weight Rating (GVWR) (); href="http://www-5.dodge.com/towing5/D/vehicle_2_weight_results.jsp?franchise=D&year=5&familyMarket=U&familyDivision=T&vehicleFamily=RAM_2500&model=2500+SLT&bdy_style=U%255ET%255ERAM_2500%255E5%255E2500+SLT%255EQUAD+CAB%255E4WD&bed_wheel=U%255ET%255ER#"> = 8800 lbs
Payload (); href="http://www-5.dodge.com/towing5/D/vehicle_2_weight_results.jsp?franchise=D&year=5&familyMarket=U&familyDivision=T&vehicleFamily=RAM_2500&model=2500+SLT&bdy_style=U%255ET%255ERAM_2500%255E5%255E2500+SLT%255EQUAD+CAB%255E4WD&bed_wheel=U%255ET%255ER#"> = 1950 lbs
Curb Weight (); href="http://www-5.dodge.com/towing5/D/vehicle_2_weight_results.jsp?franchise=D&year=5&familyMarket=U&familyDivision=T&vehicleFamily=RAM_2500&model=2500+SLT&bdy_style=U%255ET%255ERAM_2500%255E5%255E2500+SLT%255EQUAD+CAB%255E4WD&bed_wheel=U%255ET%255ER#"> = 7050 lbs
Curb Weight Front/Rear = 4358 lbs/4358 lbs
GAWR Front/Rear (); href="http://www-5.dodge.com/towing5/D/vehicle_2_weight_results.jsp?franchise=D&year=5&familyMarket=U&familyDivision=T&vehicleFamily=RAM_2500&model=2500+SLT&bdy_style=U%255ET%255ERAM_2500%255E5%255E2500+SLT%255EQUAD+CAB%255E4WD&bed_wheel=U%255ET%255ER#"> = 5200 lbs/6010 lbs
Gross Combination Weight Rating (GCWR) (); href="http://www-5.dodge.com/towing5/D/vehicle_2_weight_results.jsp?franchise=D&year=5&familyMarket=U&familyDivision=T&vehicleFamily=RAM_2500&model=2500+SLT&bdy_style=U%255ET%255ERAM_2500%255E5%255E2500+SLT%255EQUAD+CAB%255E4WD&bed_wheel=U%255ET%255ER#"> = 20000 lbs
With 4.10 Axle Ratio Axle Ratio (); href="http://www-5.dodge.com/towing5/D/vehicle_2_weight_results.jsp?franchise=D&year=5&familyMarket=U&familyDivision=T&vehicleFamily=RAM_2500&model=2500+SLT&bdy_style=U%255ET%255ERAM_2500%255E5%255E2500+SLT%255EQUAD+CAB%255E4WD&bed_wheel=U%255ET%255ER#"> You Can Tow 12800 lbs
So it looks like I am right at capacity with 2 horses at 1800 total and tack etc.? Is this too much for my truck?  I really do appreciate all the help.
Edited by lindszo 2009-01-01 11:49 AM
hogtownboss
Posted 2009-01-02 11:07 AM (#96818 - in reply to #96795)
10001001001002525
Yes, some trailers out there really do not have the correct axles, tires and wheel therefor the trailer does not show the correct weight!  So if you was going by the tag on the trailer you figures could be off.
Edited by hogtownboss 2009-01-02 3:45 PM
rose
Posted 2009-01-02 12:03 PM (#96819 - in reply to #96625)
10005001002525
Those manufacturer guides do not include pulling a gooseneck do they?  I have an 06 Ram 2500 regular cab long bed auto trans and pull an 8' lq 3 horse with it.  I had 3k pounds of feed in the bed recently and the truck did feel unstable, but never has with the trailer, so can anyone explain about the difference between pulling a conventional hitch and pulling a gooseneck?
hogtownboss
Posted 2009-01-02 12:46 PM (#96821 - in reply to #96819)
10001001001002525
The gooseneck will put more weight over and in front of the axle. The bumper pull or "conventional hitch" puts the weight behind the axle!
"I had 3k pounds of feed in the bed recently and the truck did feel unstable"
Did you have this toward the back of the bed or where? If you had it toward the back, this is the problem, when hauling that much weight it needs to be more toward the front of the bed or over the axle.
My 07 Dodge books shows info on conventional hitchs and 5th wheel hitches which is the close to the same type set up at the gooseneck hitch. (mounts in the same location)
gabz
Posted 2009-01-05 3:01 PM (#96969 - in reply to #96625)
1000100100100252525
From Lindzso:
Actually, you have a margin of 2800 pounds for horses, tack, passenger, and feed.  12,800 pound max minus 10,000 pound trailer.
However, using 20% of 12,800 is 2560 pounds in payload and your truck ratings show a payload of only 1950.
Adding the loaded weight of the trailer (12800) to the curb weight of your truck (7050) is still under your GCWR of 20,000.
Depending on where you'll be hauling - if it's all flat - you'll probably be okay. However, if you live in the mountains, you might want to reconsider the wear and tear on the tow vehicle.
You also have to take into consideration water weight in the trailer tanks.
Good Luck reaching your decision.
lindszo
Reg. Feb 2008
Posted 2009-01-06 9:00 PM (#97082 - in reply to #96969)
Thanks to everyone for all your help.
Gabz you made it simple and clear.
Jump to page : 1 2
