DIY 3H Elite DR conversion
Last activity 2008-12-28 3:25 PM
3 replies, 4995 views
nelsoncindyw
Posted 2008-12-28 12:46 PM (#96583)
Subject: DIY 3H Elite DR conversion
How do you get the rigid insulation to conform to the curve of the wall ? Also, does any one have the link to the site of a DIY conversion, I can not find it now that my husband is ready to do it !
wildcat
Reg. Jul 2008
Posted 2008-12-28 1:44 PM (#96585 - in reply to #96583)
Subject: RE: DIY 3H Elite DR conversion
http://todd.redwrench.com/
Is one of my favorites, but there are many others.
Also check out the Albums on this site.
Posted 2008-12-28 3:20 PM (#96588 - in reply to #96583)
Originally written by nelsoncindyw on 2008-12-28 1:46 PM
How do you get the rigid insulation to conform to the curve of the wall ?  !
You cut parallel longitudinal slits in the backside of the insulation about 2/3 rds the thickness of the insulation. This will allow the insulation to bend while still retaining its surface integrity.
HWBar
Reg. Nov 2005
Posted 2008-12-28 3:25 PM (#96589 - in reply to #96583)
1000100100252525
If you are talking about the inside of the top rail I just use piece of batting type insulation in there, then run your wallboards up into that area, then run you ceiling boards over to create a square. It makes it alot easier to mount cabinets if you eliminate the curve.
