rubber matting
Last activity 2008-11-27 7:03 PM
14 replies, 6686 views
mgoz
Reg. Nov 2008
Posted 2008-11-16 10:14 AM (#94963)
Subject: rubber matting
My wife and I just bought a used 3 horse slant goose neck horse trailer. It is a Titan and they put plastic on the horse walls instead of rubber matting. We are going to change it out. Can you use regular floor matting and if you can what would be the best way to attach it to the walls? Thanks for any help!
Mark
Posted 2008-11-16 6:59 PM (#94977 - in reply to #94963)
Subject: RE: rubber matting
Rubber floor mats work well and last quite a while. Because of their weight, they should be screwed to the wall, There are type specific screws used in the industry for this purpose, but you can also use flat head screws with trim washers. Stainless are the best.
Pmoore
Reg. Jul 2008
Posted 2008-11-16 10:40 PM (#94982 - in reply to #94963)
I bought what is specifically wall mat that comes in a big roll from Trailer World in BG Ky, a roll that was big enough to do my 3 horse was $100 on a close out sale, it is a little lighter than floor rubber and also has a sticky back but would problably need to be screwed on.
mgoz
Reg. Nov 2008
Posted 2008-11-17 5:51 AM (#94986 - in reply to #94963)
Thank you both. I will look for the roll as that would be easier and as you said lighter. Should make the back end of the trailer quieter from road noise as well. Thanks again,
Mark
brushycreekranch
Reg. Jun 2006
Posted 2008-11-17 6:23 PM (#95013 - in reply to #94963)
500100100100100
You can probably buy the rubber matting from D&D in Seguin.
mgoz
Reg. Nov 2008
Posted 2008-11-17 6:34 PM (#95014 - in reply to #94963)
Surprisingly enough that is about the only tack store in the San Antonio area. I will check there. Thanks for the suggestion.
brushycreekranch
Reg. Jun 2006
Posted 2008-11-17 6:50 PM (#95018 - in reply to #94963)
500100100100100
We were at D&D today, that is why I knew.
Z71
Reg. Oct 2004
Posted 2008-11-17 7:33 PM (#95021 - in reply to #94963)
Is it plastic on the walls or rumber.  I've seen some trailers that use rumber and if that is what it is, I would keep the rumber over rubber, it is much stronger.
Terri
Posted 2008-11-17 7:55 PM (#95023 - in reply to #95018)
200050010010010025
I love D&D.  Haven't been there in years though......
mgoz
Reg. Nov 2008
Posted 2008-11-18 5:53 PM (#95087 - in reply to #94963)
I have no idea what rumber is. It feels like plastic but not sure, can you describe "rumber"?
Posted 2008-11-18 6:38 PM (#95089 - in reply to #94963)
http://www.rumber.com/
http://www.ncnwest.com/rmi/equip.htm
http://castleblock.com/Rumber.html
mgoz
Reg. Nov 2008
Posted 2008-11-18 6:58 PM (#95092 - in reply to #94963)
Thanks for the site info. The material does not feel that thick. Less than a quarter inch thick. I will call Titan and find out. The trailer is an 03. The online brochure states rubber walls. Not sure what they used in 03. Didn't know rumber existed. Thanks for the heads up.
Mark
Teri
Reg. Sep 2007
Posted 2008-11-26 8:23 PM (#95415 - in reply to #94963)
Subject: TV converters for trailers?
Having conversations with other trailer owners - am wondering how this converter thing is going to effect my "new" trailer ('08). I have a flat screen TV, but someone said I'd still have to have a converter, and another said that my fancy antenna on the top won't even work anymore after February. I'm sure this has been discussed earlier, but couldn't find the subject on so many pages.
Can someone help us out on what we're supposed to do?? We have Direct TV at home and I could add another to our plan, but would rather not mess with setting up a dish everytime we go camping. I just hate the thought that my neat antenna is going to be worthless after February!
Please give me your ideas.
mgoz
Reg. Nov 2008
Posted 2008-11-27 9:41 AM (#95431 - in reply to #94963)
Unless your TV has a digital tuner and your antenna is set up to receive digital signals your are not going to receive over the air signals. The converter is for your tv not the antenna. You should be able to replace the antenna with a digital signal one with little effort. This is true for your house or trailer or anywhere you are going to receive over the air signals. If you are at a campground and have a cable hook up in your trailer it does not matter.
DLM-10
Reg. Jun 2008
Posted 2008-11-27 7:03 PM (#95437 - in reply to #94963)
The antenna will be fine but you will need a converter box for tv if it doesn't have a digital tuner, probably doesn't if more than 2yrs old. I recieve our local digital channels with my antenna on the tower with great success. With digital you pretty much recieve the channel or don't get anything. Not varing levels of fuzz and snow like analog.  Rod
