Loose wheel chewed my studs
Last activity 2008-11-04 10:23 AM
2 replies, 3963 views
david
Reg. Apr 2004
Posted 2008-11-04 10:11 AM (#94238)
Subject: Loose wheel chewed my studs
Any ideas on replacing them. Which way do they turn and should I heat the drum? Thanks
Posted 2008-11-04 10:22 AM (#94239 - in reply to #94238)
Subject: RE: Loose wheel chewed my studs
Truck? Trailer? Remove the hub/drum and drive them or press them out. How did the wheel get loose?
Edited by retento 2008-11-04 10:25 AM
Posted 2008-11-04 10:23 AM (#94240 - in reply to #94238)
 Most studs have splines and are driven straight out. Support the backside of the drum around the stud, so as not to bend or damage the drum. You can back up the drum using a large socket. Usually heat is not necessary, but a large hammer and a good aim is recommended.
