short bed & goosenec k
Last activity 2008-10-10 4:12 PM
16 replies, 6214 views
reinermom
Reg. Oct 2008
Posted 2008-10-07 9:46 PM (#92733)
Subject: short bed & goosenec k
I have an '08 Chevy Crew Cab 1/2 ton short bed.  Owners manual says not to install GN hitch.  A two horse aluminum trailer would be well with in the weight restrictions. Is the recommendation against GN strictly due to potential risk of hitting rear window while manuevering trailer? Does anyone have an extended coupler for their GN?  I have found one that seems like it would help w/ the lack of clearance issues.  Any advice?
mingiz
Reg. Jul 2004
Posted 2008-10-08 5:15 AM (#92745 - in reply to #92733)
Subject: RE: short bed & goosenec k
I have an 06 F250 short bed and I put a SB1 extender on my trailer and have had no problems at all. http://mrtruck.net/popup.htm It moved the trailer back 9 inches. I think I would call Chevy and ask why you can't install a GN hitch... You don't want to void out your warranty.
Posted 2008-10-08 6:29 AM (#92747 - in reply to #92733)
(Quote) I have an '08 Chevy Crew Cab 1/2 ton short bed.  Owners manual says not to install GN hitch.
I guess it has something to do with it being a half ton truck that they don't want you drilling into the frame, install a gooseneck/fifth wheel hitch, then dropping 5000# pounds on the pin!! I really don't know. If I were paying for it, I would find out their reasoning before I started drill and voided the warranty. I guess they are afraid folks will try to overload the frame with the gooseneck.
hounddog
Reg. Dec 2005
Posted 2008-10-08 7:53 AM (#92749 - in reply to #92733)
1000100100
The goose neck hitchs I've seen none are installed by drilling.All bolt in.
Posted 2008-10-08 8:14 AM (#92751 - in reply to #92749)
Originally written by hounddog on 2008-10-08 8:53 AM
Mine is bolted to the frame using three existing holes on each side plus two more "we drilled". Some people also weld to the top and bottom of the frame rails..... BIG no no. I think GM would rather the consumer buy one of their 2500 or 3500 series trucks for "fifthwheel" towing.
Funny thing is, they list a section in the 2008 Online Order / Reference Guide   TRAILERING SPECS - Automatic with 5th Wheel or Gooseneck Hitch for the 1500 series truck... Go figure!
http://eogld.ecomm.gm.com/dmdindex.htm
2008  Silverado 1500  TRAILERING SPECS - Automatic with 5th Wheel or Gooseneck Hitch
Maximum trailer ratings are calculated assuming standard equipped vehicle, driver and required trailering equipment. The weight of optional equipment, passengers and cargo will reduce the maximum trailer weight your vehicle can tow. 15 to 25% of the trailer weight is the recommended 5th Wheel or Gooseneck kingpin load.
Model (LY2) Vortec 4.8L V8 Gas SFI(LY5/LH6) Vortec 5.3L V8 Gas SFI(LMG) Vortec 5.3L V8 SFI FlexFuel(L76) Vortec 6.0L V8 SFI
Axle
Ratio
Maximum Trailer
Weight lbs. (kg)
Axle
Ratio
Maximum Trailer
Weight lbs. (kg)
Axle
Ratio
Maximum Trailer
Weight lbs. (kg)
Axle
Ratio
Maximum Trailer
Weight lbs. (kg)
CC10703
3.737200 (3266) 3.427200 (3266) 3.427200 (3266)
  3.738200 (3720) 3.738200 (3720)
CC10903
3.737100 (3221) 3.427000 (3175) 3.427000 (3175)
  3.738000 (3629) 3.738000 (3629)
CK10703
4.107300 (3311) 3.737300 (3311) 3.737300 (3311)
  4.108300 (3765) 4.108300 (3765)
CK10903
4.107800 (3538) 3.737800 (3538) 3.737800 (3538)
  4.108800 (3992) 4.108800 (3992)
CC10753
3.736700 (3039) 3.426700 (3039) 3.426700 (3039) 3.738700 (3946)
  3.737700 (3493) 3.737700 (3493)
CC10753
w/(NHT)
      3.7310100 (4581)
CC10953
  3.426500 (2948) 3.426600 (2994)
  3.737500 (3402) 3.737600 (3447)
CK10753
4.107500 (3402) 3.737500 (3402) 3.737500 (3402) 3.738500 (3856)
  4.108500 (3856) 4.108500 (3856)
CK10753
w/(NHT)
      4.1010400 (4717)
CK10953
  3.737300 (3311) 3.737400 (3357)
  4.108300 (3765) 4.108400 (3810)
<script language=JavaScript>var imgPath="/images/lightduty/proddesc/leftnav_";var selsection = 8;var seltype = 0;function chImage(imgID, onOrOff, divnum){ if (document.layers) { if (onOrOff) { document.layers['divTop' + divnum].document ['divTopImg' + imgID].src = imgarray_dn[imgID]; } else { document.layers['divTop' + divnum].document ['divTopImg' + imgID].src = imgarray_up[imgID]; } } else { if (onOrOff) { document ['divTopImg' + imgID].src = imgarray_dn[imgID]; } else { document ['divTopImg' + imgID].src = imgarray_up[imgID]; } }} function jumpToPage(reg, div, veh, sec, page, butID){ jumplink="proddesc.jsp?year=2008®ionID=" + reg + "&divisionID=" + div; jumplink+= "&type=" + seltype + "&vehicleID=" + veh + "§ion=" + sec; jumplink += "&page=" + page + "&butID=" + butID; window.location=jumplink;}<script language=JavaScript src="/js/lightduty/xslnav.js" type=text/javascript><script language=JavaScript> numOfTops = 10; subexist = new Array(); imgarray_up=new Array(); imgarray_dn=new Array(); buttonsection=new Array(); buttonIDLookup=new Array();
<script language=JavaScript> subexist[0] = 0; buttonIDLookup[1] = 0;
 Equipmen
<script language=JavaScript> subexist[1] = 0; buttonIDLookup[16] = 1;
Ordering Info
Edited by retento 2008-10-08 8:26 AM
chadsalt
Posted 2008-10-08 8:38 AM (#92754 - in reply to #92733)
1000100100100100
Originally written by reinermom on 2008-10-07 9:46 PM
When you say shortbed, do you mean the 5.5 foot or the 6.5 foot?
Edit,
Now that I went and looked, apparently the 69.3" short box is the only option for the crew cab.  I suspect that GM feels the bed is too short for a GN/5er, hence the comment in the owners manual.
Edited by chadsalt 2008-10-08 8:49 AM
chadsalt
Posted 2008-10-08 8:43 AM (#92755 - in reply to #92751)
1000100100100100
Originally written by retento on 2008-10-08 9:14 AM
Axle
Ratio
Maximum Trailer
Weight lbs. (kg)
Axle
Ratio
Maximum Trailer
Weight lbs. (kg)
Axle
Ratio
Maximum Trailer
Weight lbs. (kg)
Axle
Ratio
Maximum Trailer
Weight lbs. (kg)
CC10703
CC10903
CK10703
CK10903
CC10753
CC10753
w/(NHT)
      3.7310100 (4581)
CC10953
CK10753
CK10753
w/(NHT)
      4.1010400 (4717)
CK10953
 Equipmen
Ordering Info
retento,
You may notice there is not GN/5er spec for the CK10543, aka crew cab short bed.
Posted 2008-10-08 8:49 AM (#92756 - in reply to #92755)
chadsalt... It the short bed in question a 6 and a half foot bed or one of those 5 foot beds? Cause that 5 foot is mighty short for a gooseneck!!
chadsalt
Posted 2008-10-08 2:11 PM (#92773 - in reply to #92756)
1000100100100100
Originally written by retento on 2008-10-08 8:49 AM
Appears 69.3"is the only option on the crew cab........going to need the GN extender just to get where the regular short bed (6 1/2 feet) started at.
gabz
Posted 2008-10-08 4:49 PM (#92784 - in reply to #92749)
1000100100100252525
And HOW in the world did you get the bolts through the bed of the truck?  I bet some holes were drilled, eh?
gabz
Posted 2008-10-08 4:52 PM (#92785 - in reply to #92733)
1000100100100252525
IN order to correctly install a GN hitch, it needs to be mounted OVER or in front of the rear axle. THe distance between that point and the back of your cab is most likely insufficient for a GN or 5th wheel.
If I had a new truck, still under warranty, I would not void the warranty by installing something my owner's manual says not to.
When the truck is no longer under warranty - then do whatever you want.
chadsalt
Posted 2008-10-08 5:30 PM (#92788 - in reply to #92784)
1000100100100100
Originally written by gabz on 2008-10-08 5:49 PM
Those of us familiar with GN hitches and such know that "drilling" in this conversation is refering to the truck's frame, not the sheet metal of the bed.
Very few (if any) modern GN hitch kits require drilling of the frame.  Drilling and welding on a vehicle frame is technically a "no, no".
farmboy
Reg. Jul 2006
Posted 2008-10-08 5:51 PM (#92789 - in reply to #92733)
i have a 04 2500HD short wheel and a B&W i my trailer has a tapered nose so you wouldn't need a extender
gabz
Posted 2008-10-09 5:29 PM (#92843 - in reply to #92788)
1000100100100252525
Originally written by chadsalt on 2008-10-08 6:30 PM
AND THAT my dear friend is the problem with so many "expert" replies. When people come here to ask questions it's because they ARE NOT FAMILIAR with stuff. So making statements such as "no drilling" then leads someone to believe that NO DRILLING is required...  which is FALSE.  A GN hitch will put holes in the bed. Sometimes, it requires holes in the frame (depending on the model and year of the truck), particularly older trucks.
chadsalt
Posted 2008-10-09 7:54 PM (#92846 - in reply to #92843)
1000100100100100
Originally written by gabz on 2008-10-09 6:29 PM
????  What "expert" reply?  Hounddog was replying to a statement made by retento, neither of them asked a question....and neither of them are a novice.
I would have to believe even the most naive poster would understand that the GN ball does not magically appear through the bed.............but I'm sure someone will appreciate you clearing that up.
hounddog
Reg. Dec 2005
Posted 2008-10-09 10:52 PM (#92861 - in reply to #92733)
1000100100
I've not seen any with bolts through the bed.Some old ones back in the 90s were like that.But all the newer ones in THIS decade bolt on.
gabz
Posted 2008-10-10 4:12 PM (#92883 - in reply to #92861)
1000100100100252525
Originally written by hounddog on 2008-10-09 11:52 PM
HUH?  How do they attach then? I have a REESE brand GN hitch. It has 2 rails that are in the bed of the truck and the bolts pass THROUGH the rails and through the bed of the truck, into BRACKETS that are attached to the frame. The head of the bolts can be seen on the top of the rails in the bed of my truck. Then, there is a plate, with the ball on it, that attaches to the rails with four pins. I had it installed on my 2002 F150, then had to have a different set of underbed brackets for my 2004 F150, and then it was reinstalled on my 2006 F150.
Because I was LEASING the truck, this was the only option for me as the small holes can be plugged.
Here you go. GO to UNIVERSAL GOOSENECK HITCH... http://www.hitchestogo.com/gooseneck_hitches.htm
When it says "no drill" that means no FRAME drilling. You still have to drill through the bed of the truck. Then there are bolts that attach the rails and brackets to the frame.
and how about this one:??
500431999-04FordF-250/F-350 Super Duty (Except Cab & Chassis Commercial)Enlarge 1 Hole
Maybe some of you need to get out more often.
The kind of hitch that I have in the bed of my truck is just as common as an underbody one. Here where there's snow and ice and crap, the turn-over and hidden balls just get frozen solid. Removing 4 pins and taking the GN plate out isn't that big of a deal. Sometimes I just put a plastic baggie over the ball and load up hay. it pushes down over everything just fine.
BUT MINE HAS BOLTS THROUGH THE BED into brackets UNDER the truck that are bolted to the frame.
