Window bars needed
Last activity 2008-10-09 9:49 AM
11 replies, 8425 views
KeepsakeFarm
Reg. Feb 2008
Posted 2008-10-07 8:33 AM (#92701)
Subject: Window bars needed
Hmmm, tried to post this before but it didn't "take."
We have a 1997 4 Star with two drop downs in front and the three buss windows in back.  The drop down have the prison bars welded in so either the window is open so the horses can get their heads out, or I have to use a screen which doesn't let enough air in.  I've even insulated the roof and added fans.  Still gets hot in there - this is Texas I guess.
Anyway, I either want to have bars permanently welded in on the windows themselves so that I can take the screens down, or BETTER, I'd like to have a frame that I can get in or out (screws?) with the bars.  Any suggestions?  Ideas of what this will cost?  Where to go to get it done?  Etc.  Thanks!
Tresvolte
Reg. Feb 2008
Posted 2008-10-07 9:13 AM (#92706 - in reply to #92701)
Subject: RE: Window bars needed
Call 4-Star. They have a drop down bar that you can add. Not sure on the cost.
KeepsakeFarm
Reg. Feb 2008
Posted 2008-10-07 9:28 PM (#92731 - in reply to #92701)
Thanks, they do have one and it's about $300 each window.  Seems pricey but I need the airflow.  Wonder if I can find a salvage trailer?
They also told me that the smaller 4 Star location is closing.  More signs of the times I guess.  That was the location close to us.
Posted 2008-10-07 9:40 PM (#92732 - in reply to #92701)
You might contact a welder that can fabricate a series of bars for your windows. It might be much less than $300 each
mingiz
Reg. Jul 2004
Posted 2008-10-08 8:20 AM (#92752 - in reply to #92701)
I had a friend that took stainless steel solid tubing and flattened the ends drilled holes in them and mounted them to the inside window frame. Worked pretty good.
KeepsakeFarm
Reg. Feb 2008
Posted 2008-10-08 3:15 PM (#92780 - in reply to #92701)
I wonder if I would ever need to have the bars come down?  Permanent seems like it would be OK, but when is the drop down option used?
KeepsakeFarm
Reg. Feb 2008
Posted 2008-10-08 3:16 PM (#92781 - in reply to #92701)
Terri
Posted 2008-10-08 3:58 PM (#92783 - in reply to #92781)
200050010010010025
Have a welder build you a frame with a hinge and screw the bars to that.
gabz
Posted 2008-10-08 5:03 PM (#92786 - in reply to #92701)
1000100100100252525
The drop down is for when you need to untie the horse before unloading.
It's used to offer water to the horse at stops when traveling long distances.
If I'm at a show and I put the horse in the trailer, I open the bars.
Sometimes at shows or events, horses are tied to the outside of the trailer and the hay net is hung inside. The bars are opened to allow the horse to eat the hay without having to move it from inside to outside.
KeepsakeFarm
Reg. Feb 2008
Posted 2008-10-08 5:14 PM (#92787 - in reply to #92701)
Thanks the $300 a window ones from 4Star would drop down.  I haven't priced just getting the bars welded in yet.
ridingarocky
Reg. Aug 2008
Posted 2008-10-08 9:17 PM (#92796 - in reply to #92731)
500100252525
Which 4 star dealership is closing; specifically?  I am in the process of ordering a BP to my specs ...... from the dealership in Willis, I think.. It's called Gulf Coast trailer sales...yes, I ordered drops on both sides, no bars, but window mesh to the butt, and drops and window mesh to the front..you're right.. it's hot as H*ll here in Texas in the summer.... I hope it's not THAT dealership that's closing.. I'm still working on getting enough overtime pay to put down on it to order
KeepsakeFarm
Reg. Feb 2008
Posted 2008-10-09 9:49 AM (#92826 - in reply to #92701)
No, it's the one in Belton, but it's a part of Gulf Coast.  I had hoped that it would develop a full fledged service department, but I have to go to Willis also.  Willis has a great service department but it's a long way from here.
Sign of the times I guess.
