How do you figure axle ratio?
Last activity 2008-10-03 11:50 AM
5 replies, 4114 views
3horse
Posted 2008-10-02 8:24 PM (#92481)
Subject: How do you figure axle ratio?
How do you figure the axle ratio?  I'm looking in my owners manual for towing info and have looked at the tag on the drivers side door frame.  Nothing stnads out.  I have a f-150, 4x4, w/ tow and off road package.
Thanks.
flyinghfarm
Posted 2008-10-02 9:44 PM (#92485 - in reply to #92481)
Subject: RE: How do you figure axle ratio?
1000100100
Crawl under there and look on the rear housing, often it is on a tag there.  Also, call a dealer, give them the VIN #, and see if they get it for you.
Posted 2008-10-02 9:55 PM (#92486 - in reply to #92481)
You can also do it mechanically by jacking the vehicle and comparing the rotation of the drive shaft to the rotation of the tire. It's more difficult to do with a posi unit. The tag is the easiest way,
chadsalt
Posted 2008-10-02 10:25 PM (#92491 - in reply to #92481)
1000100100100100
Should be a 3 digit code on or around the door post, probably will say axle code.  Google said code.
Edited by chadsalt 2008-10-02 10:27 PM
hogtownboss
Posted 2008-10-02 11:40 PM (#92492 - in reply to #92481)
10001001001002525
Check the above like everyone said, the sticker on the door will have a code then call your local Ford dealer and he can tell you for sure.
Depending on year model, 96 and older F-150's that are 4x4 with the 5.8L engine and automatic transmission is going to be a 3.55 ratio, if it has a 5.0 engine and automatic it could have 3.08's.  97 and newer 4x4's most had the 3.55 with a 4.6 or 5.4 engine, there is a few that have a higher gear such as I think a 3.08?? that is great for fuel mileage, but POOR for any type of towing!
gabz
Posted 2008-10-03 11:50 AM (#92520 - in reply to #92481)
1000100100100252525
What year is the F150?
Here's the link to a REALLY great spot...
http://www.ford-trucks.com/forums/index.php?s=
Edited by gabz 2008-10-03 11:52 AM
