Trailer ID Help
Last activity 2008-10-02 11:40 AM
10 replies, 6141 views
tallia18
Posted 2008-09-23 10:29 PM (#92014)
Subject: Trailer ID Help
i just got an older 4 horse streight load, bumper pull.
it has a plate on it that says
Lanes Trailers
71
Serial CHS701
how can i find out the brand and the year?
thank you
natalie b.
clay7
Reg. Feb 2008
Posted 2008-09-25 12:43 PM (#92091 - in reply to #92014)
Subject: RE: Trailer ID Help
If you had the full VIN we could probably figure out the year.  The brand is much more tricky as the VIN will only tell you the chassis that it was built on.
tallia18
Posted 2008-09-25 12:53 PM (#92092 - in reply to #92014)
Where do you findthe VIN on the trailer?
if i knew where to look i might be able to find it.
the 2 stickers that are on it that
might be able to tell me the brand are covered in a layer of paint. i could try stripping the paint if you think that would work?
Posted 2008-09-25 2:53 PM (#92099 - in reply to #92014)
What does it say on the "Title"?..
tallia18
Posted 2008-09-25 3:35 PM (#92101 - in reply to #92014)
It dosent have a "Title". we think it is a 1971....but are not really sure and here in michigan it dosent have to have a title. the old owner a friend of mine has had it for the last 15 years and the old owner said it didnt have a title when he got it. so.....is it somwere stamperd on the frame???? i can take a couple pictures of it if you would like...it is one of those typical dark brown trailers with the lighter tan roof. all steel. has some rust spots that need to be replacedbut the frame, tires, and insides are all really good for an old trailer....and for $400 you cant complane much.
Edited by tallia18 2008-09-25 3:37 PM
Posted 2008-09-25 4:38 PM (#92104 - in reply to #92014)
Thre's no telling what make trailer you got. The serial number may be stamped on the tongue somewhere. Post some pictures of it on one of your posts... Maybe someone will reconize it and know right up front what it is!!
Look at some pictures of older Gore, Collin-Arnt, Shoop, Bonanza, Trailet, Miley, McQuerry... Look at the older brands.
tallia18
Posted 2008-09-25 4:44 PM (#92105 - in reply to #92104)
ok thank you i will do that as soon as  can get ahold of a camara and some daylight at the same time.
thank you very much for your help
gabz
Posted 2008-09-25 5:34 PM (#92110 - in reply to #92014)
1000100100100252525
If the trailer weighs over 2499 pounds, you need a title on it in Michigan and... you need brakes on it too. (My friend ended up with a unuseable trailer because of this.
Hard to imagine a 4H under that weight.
Sometimes there is a data plate inside a door. Steel wool might be enough to remove some of the paint so you can see anything on the ones that are painted over.
Edited by gabz 2008-09-25 5:36 PM
tallia18
Posted 2008-09-25 6:14 PM (#92114 - in reply to #92110)
i was told by secritery of state that if it is older than 1989 then you dont need a title...
gabz
Posted 2008-09-26 7:08 PM (#92159 - in reply to #92114)
1000100100100252525
Older than 1989... okay. gotcha. I had a 1987 Circle J... it was 2450 pounds, I could either get a title or not. I chose to get one even though I was under the 2500.
clay7
Reg. Feb 2008
Posted 2008-10-02 11:40 AM (#92452 - in reply to #92014)
Most manufacturers will stamp the VIN on the chassis somewhere.  Unfortunately there is no uniform placement.  Basically comes down to searching.  The tongue and on frame by the wheel well seem to be popular places though.
