Removing Decals
Last activity 2008-09-26 8:27 PM
6 replies, 5177 views
NM-Rider
Reg. Jun 2008
Posted 2008-09-19 5:14 PM (#91788)
Subject: Removing Decals
Just bought my first 4H gooseneck, love it. It is Sooner aluminum and has decals that I would like to remove.  What is the best way to get these off without damaging the aluminum.  I've put the kids to work on peeling but that got boring real quick.
olehossgal
Reg. Dec 2003
Posted 2008-09-19 6:32 PM (#91790 - in reply to #91788)
Subject: RE: Removing Decals
Our miniature horse club trailer had a good-sized 'stick on' logo; when we 'moved' up to a larger trailer and needed to sell the first one, I used a heat gun to loosen and then remove it. It was a white painted? trailer, typical cargo trailer. Not sure if it'd work the same way for decals on a metal surface, however...maybe someone else would know?
Hope you can find something that works w/o taking FOREVER!
Margo, also in NM!
stablemom
Reg. Jun 2007
Posted 2008-09-19 8:16 PM (#91794 - in reply to #91788)
Many suggest using a warm hair dryer over the decal to loosen it up. Then peel away! Hope that might work!
Posted 2008-09-19 9:07 PM (#91796 - in reply to #91788)
Sometimes using a hair dryer doesn't produce enough heat to soften the adhesive. After the decal is removed, bug and tar remover usually removes the adhesive from a painted surface.
clay7
Reg. Feb 2008
Posted 2008-09-25 1:08 PM (#92093 - in reply to #91788)
Most sign companies have tools you can purchase for around $25 that are designed just for this purpose.  While I personally have not had the need to use one I have heard great results.  Hair dryer will often work as well but as Gard said does not always generate enough heat.
gabz
Posted 2008-09-25 5:24 PM (#92109 - in reply to #91788)
1000100100100252525
If the hair dryer isn't hot enough, put a towel over the decals and iron them.  That is, if you OWN an iron. LOL...
daisycake123
Posted 2008-09-26 8:27 PM (#92162 - in reply to #91788)
3-m makes a liquid that takes decals and goo off.  Any parts store should be able to get it we just sold the shieriff dept 4 quarts.
