Removing Old Decals
Last activity 2008-08-27 7:12 AM
5 replies, 4463 views
Campchick
Reg. Mar 2008
Posted 2008-08-25 10:12 AM (#90314)
Subject: Removing Old Decals
Does anyone have any suggestions on how to remove an old decal without scratching the paint or aluminum? We have an Exiss trailer and the logo decal is coming off. We have since receive a new decal to put on from Exiss, but we are afraid of scratching the trailer while trying to get the decal off. Any suggestions is appreciated.
Tresvolte
Reg. Feb 2008
Posted 2008-08-25 10:21 AM (#90316 - in reply to #90314)
Subject: RE: Removing Old Decals
Use a blow dryer to heat it up as you pull it off. Lots of times it will come off in one piece. If it leaves behind a glue residue, you can use a tar and bug remover or goof off to remove that. Clean the area with alcohol before you apply the new decal.
gabz
Posted 2008-08-25 3:39 PM (#90343 - in reply to #90314)
1000100100100252525
Call Exiss and ask for their recommendations.
Otherwise I agree with warming it up and peeling slowly.  I used an iron one time to heat up contact paper to make it peelable.
Simple Green might be a good cleaner, but again, check with Exiss.
Campchick
Reg. Mar 2008
Posted 2008-08-26 7:36 AM (#90386 - in reply to #90314)
Thank you for your suggestions. I've e-mailed Exiss to see what there thoughts are. Thanks again
crowleysridgegirl
Reg. Apr 2005
Posted 2008-08-26 5:25 PM (#90449 - in reply to #90316)
2000500100
Originally written by Tresvolte on 2008-08-25 10:21 AM
Do you mean "goo gone"?
Tresvolte
Reg. Feb 2008
Posted 2008-08-27 7:12 AM (#90494 - in reply to #90314)
No, but goo gone will work too. Same type stuff.
