Bison living quarters trailer
Last activity 2009-03-06 11:29 AM
12 replies, 8904 views
cowgirlsmom
Reg. Aug 2008
Posted 2008-08-13 11:08 AM (#89645)
Subject: Bison living quarters trailer
Considering purchasing a Bison Stratus express with slide out. Any feedback/experience. Looking at an '08 model.
Posted 2008-08-13 11:14 AM (#89646 - in reply to #89645)
Subject: RE: Bison living quarters trailer
Do a search on Bison, there are many threads
KCW
Posted 2008-08-14 9:50 AM (#89693 - in reply to #89645)
Is it 7' or 8' wide?
An 8' wide trailer gives the horses more room and it makes a difference in the LQ's - people room. That extra foot makes a big Difference, great option.
Edited by KCW 2008-08-14 9:54 AM
clay7
Reg. Feb 2008
Posted 2008-08-20 5:57 PM (#90066 - in reply to #89645)
Good price for all aluminum trailer.
TPenning
Reg. Feb 2008
Posted 2008-08-21 8:19 AM (#90100 - in reply to #89645)
I have no personal experience with them, but was on a trail ride close to home just 2 weeks ago, and only 3 trailers there had LQ, and all 3 were Bisons.  Maybe that says something?
RodeoFoto
Reg. Feb 2009
Posted 2009-02-23 9:02 PM (#100024 - in reply to #89645)
Why are these trailers so much less exspensive then other brands.
What is the catch?
Posted 2009-02-23 10:41 PM (#100026 - in reply to #89645)
I've never owned or inspected a Bison. To answer your own question, it would be a good idea for a hands on look. Usually when one item is less expensive than a comparable item, it is a result of different materials, different construction, or different workmanship. Just as with steel, not all aluminum trailers are built the same. The materials' choices and the amount of them, vary considerably from manufacturer to manufacturer.
To answer your question, you will have to inspect trailers of a known quality and price, and directly compare them to the Bison. Read as much as you can from the owners of them, and talk to the people who sell competitive brands. Most will be more than willing to enumerate their faults, which if you take them with a grain of salt, will give you an idea where to look for differences.
Bison, I think, builds its own interiors in house. This would be less expensive than farming them out to conversion companies. Having a standardized interior is one way to save money.
Another savings is to use lighter axles and cheaper tires. Compare the Bison's so that you are likening apples to apples. Check the frame construction and welds, the hardware, the drop down window hinges and construction, the doors, stall dividers, the fit and finish, all before you step inside the LQ.
Most people will buy a trailer, based upon the looks, the colours and layouts of the LQ. The LQ, like a house, is nothing without a foundation. Pretty doesn't haul the horses, day after day, safely over thousands of miles.
We've had rusting frames in the Sundowner, sagging floors in the 4 Star, bad doors in the Kieffer, exploding roofs of the Exiss and now burning Bison. Nothing is sacred.
levie
Reg. Jan 2009
Posted 2009-02-24 6:48 AM (#100033 - in reply to #89645)
Bison Use to do their LQ near Elkhart In. I think they are still located in  Napanee. The are very close to all the venders that they need usualy if you are withen a 50 mile range you dont have to pay shipping on all of your material. so it save a ton. If your LQ weighs aprox 2-4 thousand lb and your avreage shipping cost is  $4.00-$6.00 a lb that adds up. Also their is alot of RV wearhouses hear. if you have set floor plans verses custom you can buy in bulk. If you buy in bulk lets just say a semi load of panneling verses a 10 sheets of custom you also save alot. I have owend a Bison. and It did Its Job For years. It got me and my children and horses safely to the shows for years.
ClaudiaIN
Reg. Feb 2009
Posted 2009-02-24 8:56 AM (#100046 - in reply to #89645)
If I understand it correctly -- the "Express" model doesn't have a few things that the others do- so that cuts the price-- not as many outside lights-- doesn't have the cover in front where the tanks, etc are.
We know several people that have Bisons and they all are happy-  that was what we were looking at till we found our trailer recently
DD_TrailerMan
Reg. Jul 2008
Posted 2009-02-27 8:15 AM (#100275 - in reply to #89645)
Hey Kate
I sent you a PM
RodeoFoto
Reg. Feb 2009
Posted 2009-03-05 1:10 PM (#100731 - in reply to #89645)
Is the 8 Ft wide a must?
Has anyone seen that brown interior?  Any thoughts on that?
D sq
Reg. Feb 2007
Posted 2009-03-05 5:12 PM (#100747 - in reply to #89645)
We have an 06, Bison 4 horse, 8 ft. short wall. We ahve had no problems with it, except tires. our first set started popping at about 8,000 miles. The second set I got, lasted about 10,000 miles. I keep the correct tire pressure, rotate tires 2 times a year. The next set I buy I am going to get "G" rated tires instead of "E" rated that came on the trailer. Other than that, we love our Bison.
Snickers
Posted 2009-03-06 11:29 AM (#100794 - in reply to #89645)
Dsq, what make of tires were and are on your trailer? If you do go to the G rated tire make sure that your rims are rated for 110 psi. Not sure but I think the G rating  runs at 110 psi and the E rating is only 85 psi. There was a post some time ago that covered this.
