Please help me understand these weights
Last activity 2008-08-07 8:35 AM
5 replies, 4980 views
Katie987
Reg. Aug 2008
Posted 2008-08-06 7:27 PM (#89156)
Subject: Please help me understand these weights
Ok, this is what I have. 2003 Dodge Ram 2500 Hemi, quad cab, also with a long box and 4x4, factory towing package. The GVWR says 8800 lbs, it also has front as 5200 and rear as 6000 lbs.
The reciever I have says GPCSS wt 6000 lbs
Tongue Weight 600 lbs.
I'm not sure what it all means. If I want to pull an old steel stock trailer with two or three horses in it, am I good or do I need a new reciever. Just not sure what all these #s mean?!? 45
Posted 2008-08-06 7:54 PM (#89158 - in reply to #89156)
Subject: RE: Please help me understand these weights
Your reciever will pull a 6000lb trailer as long as it's tongue weight does not exceed 600lbs.
3 horses at about 1000lbs each = 3000lbs.  So as long as the trailer does not weigh more than 3000lbs empty, you should be fine.
Katie987
Reg. Aug 2008
Posted 2008-08-06 8:12 PM (#89159 - in reply to #89156)
Ok thanks, guess I'll have to go weigh it all when hooked up. What does tongue weight mean exactly?
Towfoo
Reg. Jan 2008
Posted 2008-08-06 8:36 PM (#89162 - in reply to #89159)
100100252525
Originally written by Katie987 on 2008-08-06 8:12 PM
It's the downward weight of the trailer's "tongue" (where the trailer's coupler sits on the hitch ball).
Posted 2008-08-06 9:23 PM (#89163 - in reply to #89156)
As he said it's how much weight actually sits on the ball, This would be the trailer weight minus the weight that sits on the trailer tires.
The tow weight it has much the trailer weighs in total. Or how much weight you drag forward with the truck.
Another piece of the puzzle is how much weight your ball is rated for. A class II ball will not carry the same weight as a Class III.  So even if your reciever is rated to carry the load, your stinger or ball mount and the ball must both be rated for an equal or greater capacity. You can look on the top of the ball to read it's rating.
Edited by Painted Horse 2008-08-06 9:28 PM
gabz
Posted 2008-08-07 8:35 AM (#89181 - in reply to #89156)
1000100100100252525
Here's some more help.
Your tongue weight, as described, is considered payload on your truck.
If your GVWR is 8800 pounds, that is your limit on total truck "weight". You need to know how much your truck weighs. Add the tongue weight to that, plus passengers and cargo. If that does not exceed 8800 pounds - then you are within specs for the truck.
