Electric problems
Gofer
Reg. Jun 2026
Posted 2026-06-24 11:50 PM (#186126)
Subject: Electric problems
The 12v system only works when plugged in to 120v. If you turn off main battery switch, all electric drops out. Replaced battery and converter. Help please and thank you!
Posted 2026-06-26 6:18 PM (#186128 - in reply to #186126)
Subject: RE: Electric problems
Did you or someone else replace the battery & converter?
Do you know how to use a voltmeter or test light ?
Gofer
Reg. Jun 2026
Posted 2026-06-26 8:20 PM (#186129 - in reply to #186126)
Trailer belongs to a friend. They replaced the converter and battery. Yes, I do have a volt meter. I can't find any reason for this to happen. When you turn off main battery switch 12v and 120v drops out. The electric jack works fine.
Gofer
Reg. Jun 2026
Posted 2026-06-26 8:22 PM (#186130 - in reply to #186129)
Thank you for replying!
Posted 2026-06-29 2:57 PM (#186134 - in reply to #186126)
Sounds like the battery switch is disconnecting the battery from the trailer system. That's how it's supposed to work. The trailer jack still works because its power does not go through the switch.
