U4GM: ARC Raiders Agave Farming Tips for Scrappy
1fuhd
Reg. Apr 2026
Posted 2026-04-14 1:06 AM (#186078)
Subject: U4GM: ARC Raiders Agave Farming Tips for Scrappy
Agave is important because it's one of the food items Scrappy can use, so collecting it efficiently helps you keep up with his upgrades and avoids wasting time scavenging randomly. The best approach is usually to gather it while moving through areas with lots of harvestable plants or containers. Players who plan routes around these spots tend to stock up faster than those who search every building aimlessly ARC Raiders Coins.
The most reliable source is the Agave plant itself. Interacting with the plant typically gives one Agave, though the prompt can be easy to miss, so a careful loop around the plant often helps. Some guides point out that plants hidden in outer-map foliage can also be harvested directly, so it's worth checking clusters near rocks, trees, and low-cover terrain, not just obvious garden patches. When farming on foot, scan the ground carefully because Agave often blends into the environment.
Wicker baskets are another potential source. Videos from Buried City show that baskets in places like Marano Park can contain fruit and sometimes drop Agave, while other guides suggest checking baskets during Lush Blooms events. These baskets aren't as reliable as the plants themselves, but they're a good backup when you need an extra piece or two.
For the fastest farming loop, sticking to map edges and open natural zones, especially during Lush Blooms, which seems to increase the chance of finding harvestable items. Moving along the outer boundaries of the map tends to be more productive than staying in crowded central areas. Marano Park and Pale Apartments are popular spots because multiple plants can be harvested in a single pass. The key is to pick a plant-dense zone and sweep it methodically rather than chasing individual spawns.
It's also important to remember that Agave is just one part of Scrappy's food economy. Collecting fruits and upgrade materials like lemons, apricots, olives, and prickly pears at the same time is also important. Gathering multiple items in one run is more efficient than making separate trips for each resource. A practical loop might start in a green zone, check baskets, harvest all visible plants, and move on before the area gets crowded ARC Raiders Coins cheap.
In combat, Agave is better thought of as a backup heal. It restores only a small amount of health, so it's most useful for topping up between fights rather than relying on it during heavy damage. Keep some in your quick-use slot for long expeditions, but the main value comes from steadily collecting it over time, not depending on it as a primary survival tool. By moving in loops and staying alert for plants that blend into the scenery, you can usually collect enough Agave faster than expected.
