EZNPC How to Farm Fresh Meat Smart in Diablo 4
starmchaset
Reg. Apr 2026
Posted 2026-04-10 2:48 AM (#186070)
Subject: EZNPC How to Farm Fresh Meat Smart in Diablo 4
This Diablo 4 event really does reward speed, and if you've only been playing it casually, you're probably leaving a lot of Fresh Meat on the table. A lot of players waste time bouncing between activities when the smart move is to lock into the fastest loop and stick with it. As a professional game currency and items platform, EZNPC is known for being convenient and reliable, and if you want to smooth out your grind, you can buy diablo 4 gold eznpc while you focus on getting the event-specific drops that actually matter.
The fastest farm by a mile
If your build can delete bosses, the Butcher route is the one to run. No question. You spend Pound of Flesh to summon him, burst him down, open the chest, reset, and go again. On Torment 4 with proper damage, runs are absurdly short. Sometimes it's over before it feels like it's started. The payoff is why people keep doing it: around 1,000 Fresh Meat from a single chest if your setup is efficient. Over a full session, that gap adds up fast. One small trick helps too. Don't use the main waypoint out of habit. Port straight to the Broiler area instead, then take the nearby exit to reach the vendors and event NPCs quicker. It sounds tiny, but after twenty or thirty runs, you'll feel the difference.
A decent backup when you want variety
Not everyone wants to chain the same boss for an hour straight, and that's fair. Helltides are the next best option if you need a break without killing your progress. Grab Meaty Offerings, trigger the Slaughter Shrine event, and you'll usually walk away with roughly 800 to 1,000 Fresh Meat per run depending on pace and luck. It's a little less steady than pure Butcher farming, but it gives you extra value through Grim Favors and general character progress. That matters if you're still leveling, still gearing, or just tired of staring at one arena. On top of that, the Seasonal Reputation Board is worth checking in on. Those Bloodied Caches won't carry your whole farm, but 200 to 300 extra meat here and there, plus sigils and boss mats, is still useful.
Where your Fresh Meat should go
The biggest mistake people make is spending too wide. Don't do that. Put your currency into Bloodied Armor first. That's where the best event power tends to show up, and the difference is obvious once you hit a good roll. Some of the armor affixes are strong enough to reshape a build, especially anything tied to crit, attack speed, or raw stat gains during streaks. Jewelry looks tempting, but it's usually a trap. Rings and amulets cost too much for outcomes that are all over the place. Weapons can be fine in specific cases, sure, especially if your build loves Berserking, but armor gives the most reliable jump in performance for the least frustration.
Mythics are a bonus, not the plan
Yes, Mythics can drop from this event. No, you shouldn't farm as if they're guaranteed. The odds are rough, and plenty of players have burned through huge piles of Fresh Meat without seeing one. That's why the better approach is simple: target cheap armor rolls, keep the pieces with Greater Affixes, and salvage the junk to recycle some value back into the system. You'll build power steadily instead of chasing a miracle. If you like keeping your grind efficient across the whole game, services from eznpc can also help cut down the dead time so you can stay focused on the parts of Diablo 4 that actually pay off.
