| If you're diving into Arc Raiders, you’ve likely encountered Electrical Components while scavenging or crafting. These are essential materials used to craft various utility items and can be recycled into valuable crafting materials. But how do you get them? Here's a breakdown of everything you need to know about acquiring Electrical Components in the game.
What Are Electrical Components?
Electrical Components are classified as "uncommon" items in Arc Raiders. They are primarily used in crafting but can also be recycled into other crafting materials. These components play a key role in the crafting process, allowing you to create utility items and upgrade essential equipment.
While they may not be as commonly dropped as some other materials, they are an important part of progression in the game. Plus, they are involved in crafting some advanced items like the Jolt Mine and Tactical Mk. 2.
How Do You Get Electrical Components?
There are several ways to get your hands on Electrical Components in Arc Raiders. Here's how to go about acquiring them:
1. Scavenging
The most common method of obtaining Electrical Components is through scavenging. You’ll find them in the Electrical category while exploring. Look for loot crates, electrical panels, and other items scattered throughout the world. These components can drop from these sources as part of your regular scavenging efforts.
In practice, players often spend time going through electrical-related loot piles during missions or while exploring zones where tech items are more abundant. Be patient, as it can take a few runs to gather a decent stock of these materials.
2. Crafting Electrical Components
If you have the right resources, you can also craft Electrical Components. To craft them, you’ll need:
8 Plastic Parts
4 Rubber Parts
This can be done at Refiner 1, the first tier of the crafting stations. Once you have the necessary ingredients, simply combine them in the crafting menu to create one Electrical Component.
This method is particularly useful if you have a surplus of Plastic and Rubber Parts. Many players keep crafting materials on hand just in case they need to craft these components on the fly during their expeditions.
3. Recycling Other Items
Another way to acquire Electrical Components is by recycling or salvaging other materials you no longer need. If you have items like Advanced Electrical Components or Combat Mk. 2, you can recycle them into Electrical Components. For example, recycling one Combat Mk. 2 results in one Electrical Component.
Recycling is a great way to clear out old gear while also gathering valuable components. It’s an efficient way to stock up on materials without having to actively search for them.
4. Salvaging
When you salvage items, you can also get Electrical Components as part of the process. Salvaging certain items such as Snitch Scanners and Hornet Drivers will return Electrical Components as a part of the salvaging yield. Keep an eye on items that may be used for salvaging if you’re in need of a quick Electrical Component boost.
What Are Electrical Components Used For?
Once you have gathered a good number of Electrical Components, they can be used for crafting various items. Some of the more notable items that require Electrical Components include:
Combat Mk. 2 (used in combat gear crafting)
Jolt Mine (requires Electrical Components and a Battery to craft)
Looting Mk. 2 (used in looting enhancement)
Tactical Mk. 2 (part of combat upgrades)
Electrical Components are also involved in crafting advanced items like Advanced Electrical Components, Surge Shield Recharger, and other key equipment upgrades.
Recycling and Salvaging for Extra Materials
In addition to their crafting use, Electrical Components can also be recycled or salvaged for other materials. Recycling Electrical Components yields items like Plastic Parts and Rubber Parts, which are handy for crafting other common components. Salvaging Electrical Components can also give you additional materials, but make sure you’re ready to part with your gear.
Should You Buy Arc Raiders Blueprints?
As you progress in Arc Raiders, you may find yourself looking for blueprints to craft more advanced items. If you want to save time and focus on gameplay rather than spending hours scavenging, buying Arc Raiders blueprints from a trusted marketplace might be a good choice. These blueprints allow you to access powerful equipment and upgrades without having to rely solely on the randomness of drops.
By acquiring blueprints, you can tailor your crafting strategy, ensuring you get the exact items you need without unnecessary grinding. Whether you’re looking to create better combat gear, build stronger utilities, or level up your craft, blueprints are a valuable shortcut.
Electrical Components are an essential item in Arc Raiders, and knowing how to gather them efficiently can significantly improve your crafting and overall progression. Whether you’re scavenging the world for loot, crafting them from basic materials, or recycling old gear, make sure you stockpile these components. They’re useful for creating many important items, from basic utilities to advanced combat equipment.
And if you're looking for more advanced equipment or want to streamline your crafting process, consider buying Arc Raiders blueprints. It’s a great way to quickly access the gear and items you need to tackle tougher challenges in the game.
Tempest Blueprint | All Platform | |
