Location: las cruces, nm | I have a slide-in camper with an overhang....I want to tow a 2 horse bumper pull...any recommendations/comments?
Edited by clayton991 2008-08-03 8:47 AM
      Location: Rocky Mount N.C. | Lengthen the tongue of the trailer the same length of the overhang of the slide in camper..... DO NOT EXTEND THE TRUCK HITCH!! It's a Physics thing. Read these posts... http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=8314 http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=8906 |
    Location: Roanoke IL | I will beg to differ. If you use the torklift superhitch, you are getting a tested, proven, load rated solution to your problem. When you extend the tongue of your trailer, you aren't quite sure of what you're getting. Hopefully the person who does the job does it right. Now, all that having been said, I had a tongue extension put on my trailer. They beefed up the trailer frame, then they added the extension. It was a separate piece that had a ball that went into the coupler, bolted to the frame, and was built like a brick poop house. However.....I was always worried because I didn't know what that hitch was rated for since it was basically someone's home project. It worked fine for a steel 4 horse stock trailer. My camper overhang was a GOOD 3 feet. Big. If I had the money I'd do the torklift superhitch. I had a lot more bounce of the trailer when the tongue extension was in place. With torklift The research and numbers are all there. If I had a new truck and trailer worth THOUSANDS of dollars I would not cut corners on the hitch situation. Do some asking on truck camper forums, and the satisfaction with the torklift superhitch is overwhealming. I believe they even have a picture or video of a truck pulling a horse trailer with a truck camper on their website. You will need to use a weight distribution system though....if I remember correctly. This is just my honest opinion from experience. I've never been one to question physics, but someone from torklift must have. There are LOTS of people using these hitch systems without problem. Amanda |
      Location: Rocky Mount N.C. | Originally written by Angelmay84 on 2008-08-03 10:31 AM I will beg to differ. If you use the torklift superhitch, you are getting a tested, proven, load rated solution to your problem. When you extend the tongue of your trailer, you aren't quite sure of what you're getting. Hopefully the person who does the job does it right. Now, all that having been said, I had a tongue extension put on my trailer. They beefed up the trailer frame, then they added the extension. It was a separate piece that had a ball that went into the coupler, bolted to the frame, and was built like a brick poop house. However.....I was always worried because I didn't know what that hitch was rated for since it was basically someone's home project. It worked fine for a steel 4 horse stock trailer. My camper overhang was a GOOD 3 feet. Big. If I had the money I'd do the torklift superhitch. I had a lot more bounce of the trailer when the tongue extension was in place. With torklift The research and numbers are all there. If I had a new truck and trailer worth THOUSANDS of dollars I would not cut corners on the hitch situation. Do some asking on truck camper forums, and the satisfaction with the torklift superhitch is overwhealming. I believe they even have a picture or video of a truck pulling a horse trailer with a truck camper on their website. You will need to use a weight distribution system though....if I remember correctly. This is just my honest opinion from experience. I've never been one to question physics, but someone from torklift must have. There are LOTS of people using these hitch systems without problem. Amanda http://www.torklift.com/p.php?w_page=superhitch That looks like the tail wagging the dog..... No thanks, I'll pass on that "quick fix".
Edited by retento 2008-08-03 10:18 AM
Location: las cruces, nm | Thanks Amanda.... I haven't made a decision yet, but I have spoken to two people who are using the Superhitch successfully. But....there are limitations....road dips, reduced speed in the wind, and plain old careful driving (don't weave!...leave the beer at home!). So, I'm continuing my research, but my options are limited. The trailer is new so I won't be welding anything untested onto it, and the camper is new so I won't be selling it. Thanks again, Rich |
  Location: Jeddo, MI | I have a short bed with an 8.5 ft. camper. Instead of buying the torklift I had a fabricator extend the tongue of the trailer. I have put many miles on this setup with no sway and no problems. It saved about $400.00 going this route. I went with the torklift tiedowns, and added airbags. The airbags were definately needed and make all the difference when steering and leveling the truck with that much weight. debbie |
       Location: western PA | I carried campers and pulled BP trailers for many years. Even with the camper specials and trailer towing package options, a stock SRW truck does some bobbing and weaving under certain conditions. You will be down on your helpers with the combination, and with any corner or wind, the truck will sway. Air bags or Timbrens are a must for stability. You can do a search for the comparisons. Extending the hitch makes matters worse, it adds additional weight behind the axle in greater amounts than the actual tongue weight. It's risky finding a competent welder to cut up a good trailer, but adding the extra length to the tongue is a safer way to go. You will only increase the turning radius of the trailer and add a small amount to the tongue weight. If the conversion is done correctly, it won't effect your trailer's stability or towing capabilities. With the combination, you will be up against most 3/4 and 1 ton trucks' weight carrying capabilities. Be careful in cross winds and jack knifing when backing up. BOL Gard |
      Location: La Cygne, KS | Is your tow vehicle SRW or DRW? |
  Location: Jeddo, MI | My truck is 2006 Dodge Ram Mega Cab with a short bed. It is not a dually. The airbags are a must. I started without airbags and the truck was not level when loaded and the steering was off. I weighed everything and am a small amount over on payload and that is where the airbags have helped. |
