trailer wiring
wilkinstr
Reg. Jul 2008
Posted 2008-07-28 8:37 PM (#88446)
Subject: trailer wiring
I have a F-250 93 model and cant for the life of me figure out the wiring so I can have brakes
tobruk
Posted 2008-07-28 9:07 PM (#88453 - in reply to #88446)
Subject: RE: trailer wiring
If you go to the bottom of the Home page there's a great article with diagrams on trailer wiring, and trucks.  You have to install a brake controller/actuator of some kind too up under the dash.  The wire from that goes back into the correct slot on the truck plug to correspond with the trailer plug you're using.
Posted 2008-07-28 9:24 PM (#88454 - in reply to #88446)
Under the dash, near the top of the steering column, usually on the right side, is an open female 4 pin receptacle. From Ford and some auto parts stores, for about $10 you can purchase a male 4 pin plug that will fit. The plug is wired with colour coded wires that are used to wire into your aux brake controller. One will be a source hot, a ground, lead from the truck's brake pedal and hot to the trailer.
The controller is usually mounted to your lower dash where you have an easy access for adjustments. It's an easy do it yourself type of job, that many dealerships charge about $100 for the installation. You should have a six or seven pin plug on the rear of your truck for the trailer plug.
BOL  Gard
