WHAT KIND OF SHOWER STALL DO I NEED??
nhmelmac
Reg. Jun 2008
Posted 2008-06-28 9:01 AM (#86544)
Subject: WHAT KIND OF SHOWER STALL DO I NEED??
I live in the Northeast. No one here builds LQ's. Do I need a special shower for the LQ's, or will any shower stall work?
Thanks for helping, I'm a beginner who needs support and lots of luck!
MM
Posted 2008-06-28 9:16 AM (#86546 - in reply to #86544)
Subject: RE: WHAT KIND OF SHOWER STALL DO I NEED??
LQ showers are typically smaller than household types. They are also usually non standard sizes, to fit the space requirements offered within the confines of camper construction. If you do a search, your question has been previously asked many times, and several source references have been given. Occasionally you can find shower inclosures on Ebay.
BOL    Gard
Turfa
Posted 2008-06-28 12:27 PM (#86558 - in reply to #86544)
Ebay Camper parts has a base.  See attached.
http://cgi.ebay.com/ebaymotors/RV-TRAVEL-TRAILER-CAMPER-5TH-WHEEL-SHOWER-PAN_W0QQitemZ300236352021QQcmdZViewItem?hash=item300236352021&_trksid=p3286.m14.l1318
Good Luck
Turfa
Rockinghorserun
Posted 2008-06-29 8:27 PM (#86658 - in reply to #86544)
I bought a trailer with a shower installed that fits and works fine.  It came from Lowes and is 32X32X72.  I believe they run under $150 complete. It is next to the sleeper on the long wall. It is self supporting and secured to the wall.  It runs straight out on the ground but I have a portable holding tank that fits under it.
HWBar
Reg. Nov 2005
Posted 2008-06-30 4:49 AM (#86670 - in reply to #86544)
1000100100252525
Alot of it depends upon space available, I have installed the showers from Lowes that Rockinhorse has described and I have installed showers that were designed for RV's, the main difference is that RV showers are usually built up a tad higher(5"-7" from floor) this is so you can install a trap under them without cutting a hole in the floor. If you are not going to install a holding tank then the trap is not needed. You can find shower pans on E-bay or from Jazz Sales, you will have to call them to find a dealer in your area.
Edited by HWBar 2008-06-30 4:51 AM
