Location: Ashland, Missouri | Where would the serial number be located on a Sidekick brand trailer? All I can find is the manufacture number. Need to order a new drop down window -- or does anyone know the part number for the windows in a Sidekick 5 horse mid & rear tack trailer? Thanks! Jspears |
       Location: western PA | All the numbers on mine are on a data plate, located under the goose sleeping area near the bulkhead on the left side (drivers). It's actually on the inside of the tapered bracing that transitions from the vertical bulkhead to the horizontal overhead. It's right at the end of the two batteries, and almost in line with them. Gard |
Location: Delta, B.C. Canada | Ours, too, is under the gooseneck area, driver's side, per the previous post. |
     Location: Tenn/Ala. | I just looked at a 11/02 unit that had it on the outside, horizontal surface of the bunk. Basically, lay on your back under the GN, and you'll see it.
RTSmith |
