Tell me about it
DaveM
Reg. Sep 2003
Posted 2008-06-12 8:59 AM (#85564)
Subject: Tell me about it
Here's my first question ever for this board.  Be kind to me.  I'm a little nervous.
These UTV's are getting popular and we're going to get one.  (John Deere Gator probably)  My question, if the wife wants to barrel race, etc. and we hook up the gooseneck, how do I bring along my toy?  Are their trailers being built that accomodate both?
barntoys4mom
Reg. May 2007
Posted 2008-06-12 9:12 AM (#85566 - in reply to #85564)
Subject: RE: Tell me about it
Marrow, Marrow on the wall.....I see a six horse ramp load in your future! (7.5 tall and 8 wide too!)
Posted 2008-06-12 9:23 AM (#85568 - in reply to #85564)
Many shows that I've been to are spread out and involve a lot of walking. Several exhibitors bring golf carts to haul their tack, feed and personnel. They attach a smaller flatbed, utility type trailer to the back of the horse trailer.
The carts in turn are equipped with a trailer hitch. When the rig arrives, the cart is unloaded and its trailer is attached to the cart, which moves it to a convenient spot out of the way. Then the horse trailer is handled and unloaded in the normal way. The carts could easily be substituted with the utes.
Before you decide on a belt driven UTV, check out some with real transmissions, 4 wheel brakes, hydraulic dump beds, diesel engines, and exemplarily carrying and towing capacities. Belt drives are weak in water conditions, wear quickly with constant towing, and changing one is difficult. Kubota RTVs with a three range hydrostatic transmission fit the bill.
I spent the first few hours of this morning moving several hay wagons, both loaded and empty with our RTV. Pulling three empty or two full is no problem and I didn't even have to use the 4wd. Once you have a ute, you will wonder how you got along without it.
Edited by gard 2008-06-12 9:36 AM
flyinghfarm
Posted 2008-06-12 9:52 AM (#85573 - in reply to #85564)
1000100100
I have a small tilt trailer that will pull the Polaris 6 wheeler handily.  And that trailer is easy to move by hand.  It was a golf cart trailer in it's other life.
brushycreekranch
Reg. Jun 2006
Posted 2008-06-12 11:19 AM (#85578 - in reply to #85564)
500100100100100
I have a Artic Cat Prowler that I just drive up into the back of my trailer. If I need all the trailer stalls for horses or mules, I just load it on to a small trailer and pull it behind my LQ trailer. When I get to where I am going, the little trailer gets unhooked first, then moved out of the way. I have a factory installed hitch reciever tube on the back of my LQ trailer that is rated for more than the UTV and trailer weighs. Some shows still allow scooters, so I prefer to take the scooter since it is less hassle.
Before the Artic Cat Prowler, we had a EZ Go workhorse. It did not perform well at all on the farm  but did well at the shows.
Posted 2008-06-12 12:09 PM (#85583 - in reply to #85564)
Some show grounds don't alow "gas powered" utility vehicles. The electric golf carts, electric gators, etc. are OK. No internal combustion engine powered vehicles allowed, no ATV's, RTV's, etc..... Go figure! We take a couple of these with us, one for me because I can't walk and another for the wife to use or for me in the event of a break down. They don't have the cool factor that a ATV has, but if ya got a leg gnawed off, then you've lost all hopes of being cool along time ago!!! They are 23" wide and 44" long, so they fit nicely in a horse stall, inside the arenas, bathrooms, offices and they are ADA compliant. The battery will last all day on an overnight charge.
Shoprider Sunrunner 4 Wheel Scooter, Red
bjhouten
Posted 2008-06-12 3:31 PM (#85591 - in reply to #85564)
5002525
Going to church doesn't make you a Christian any more than standing in a garage makes you a car
Love this line...
jim bob
Reg. Jan 2008
Posted 2008-06-12 5:19 PM (#85594 - in reply to #85564)
There are some very neat straight load trailers that have two stalls at the rear, and a large "box stall" area ahead of the stalls with an adjascent side ramp.  Some of these trailers have aluminum gates in front of the stalls, so that if the divider is removed, you now have two box stalls.  If you choose to, you can remove all hardware and have one large "utility trailer".  We sell more of this type of trailer all the time; and they can accomodate many different situations.  Your "Gator" type vehicle would probably work well with this type of trailer.
TPenning
Reg. Feb 2008
Posted 2008-06-12 7:42 PM (#85605 - in reply to #85564)
A neighbour of mine had a 36' stock trailer that divided up nicely into three 12' box stalls.  She used to load horses up front, close the divider, and drive her car in on the back and climb out through the sun roof. She used this setup for the big shows in the city where she didn't want to drive the dually around, or for when they needed more than one vehicle. Obviously this wouldn't be much help on the fair grounds....  However, if her car fit, surely a Gator could be accomodated. We load the quad in ours by removing the door post (it has collapsible rear tack).
A few years ago my daughter (who was 10) and I were 3 days into a 7 day run of shows and were gearing up for the long walk to the showers clear on the other side of the grounds.  Three 18 hour days of hoofing it had left me aching all over, but clearly she was feeling the same when she eyeballed a mini pulling a cart past us and said, "ohhhhh, mom, do you think we could hitch a ride?"
Btw, I'm also still giggling over the church/garage comparison above.  That's priceless!
KeepsakeFarm
Reg. Feb 2008
Posted 2008-06-12 8:23 PM (#85606 - in reply to #85564)
When I was out shopping for a trailer I ran across two that had been custom built to haul carts and horses.  That would be more than enough room for both.
Posted 2008-06-12 9:45 PM (#85609 - in reply to #85564)
Here are a slew of them to compare...
Use this for the shows...
http://www.4-medical-supplies.com/heavy-dutymobilityscooters/
Instead of a GATOR or its relatives...for around the farm...Get a Japanese MiniTruck!!!...
They come in many flavors...and some even have A/C...
Daihatsu
Mitsubishi
Suzuki
Subaru
Honda
Mazda
Here is where you can find all the info on them...
http://www.minitrucktalk.com/
Edited by PaulChristenson 2008-06-12 9:54 PM
DaveM
Reg. Sep 2003
Posted 2008-06-13 10:43 AM (#85628 - in reply to #85609)
Great input.    The stock combo with a center swing gate makes the most sense for my use.  Tough to find those with a drop ramp though.
wendmil
Reg. Aug 2006
Posted 2008-06-13 11:24 AM (#85630 - in reply to #85628)
Originally written by DaveM on 2008-06-13 10:43 AM
You could carry a couple of folding ramps (like the type for ATVs).
Sharon
Posted 2008-06-13 2:20 PM (#85637 - in reply to #85583)
Originally written by retento on 2008-06-12 12:09 PM
There's a woman in VT who competes in Endurance... very well known family... and she and her husband both ride Segways around ridecamp.  She even trots her horse out for the vet while riding her Segway.  Very cool to watch.
Posted 2008-06-13 3:12 PM (#85640 - in reply to #85564)
 I use my scooter to walk the horses after a class or after their bath to cool them off and help them dry. You should see me walking my Icelandic after my wife wins a Speed Racking class, boy he can get wound up!! He's about to pull my arm out of socket while dragging the scooters rear tires!!
Posted 2008-06-13 10:24 PM (#85651 - in reply to #85630)
1000500100100100252525
some trailer company's will make a stock combo with ramp if you ask. I did and it works great for the older horse to get on
Posted 2008-06-14 3:35 AM (#85652 - in reply to #85564)
Here's your new trailer!!! May need to be 8' wide instead.
http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=159151
<script> window.setTimeout("watermark()",50);
Maybe this one...  http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=161747
Edited by retento 2008-06-14 3:57 AM
DD_TrailerMan
Reg. Jul 2008
Posted 2008-07-21 8:24 PM (#87864 - in reply to #85564)
We have built a few buggie trailers, here is a picture of a custom build where the slant wall opens.
http://www.doubledtrailers.com/Customer_Testimonial.htm
Another solution would be to add a ramp to the side.  You would need a wide trailer to fit the gator if you drove the gator in sideways.
dawnb
Posted 2008-07-22 8:49 AM (#87884 - in reply to #85564)
We are thinking about looking at mini truck. My hubby heard that you can license it has an ATV and than you can legally drive on gravel an cty rds. I could drive it to work and at 50 miles to gal.(roughly) that beats the heck out of 13 mile to the gal I'm getting with my 1/2 ton pickup. I drive alittle over a mile to work.
tom-tom
Reg. Feb 2008
Posted 2008-07-22 12:47 PM (#87913 - in reply to #85564)
100100100
I agree with looking at the RTV.  We have owned one for about 3-4 yrs.  I can't live without it.  My husband hates to take it in for a service because I am one unhappy farm manager without it.  We have both cows and horses and it makes my life so much easier; just load up and go feed.  I also highly recommend the hydraulic dump bed.  I use it for dumping hay to the cows;  cleaning our horse stalls and dumping the shaving. Also recommend the windshield and the roof.
We have taken it camping also - we did not carry horses on this trip.  We had a 3H LQ at the time with a rear ramp.  We took out the stall dividers and drove it up the ramp.  The RTV fit just fine even with the manager.  Unloaded it and just backed it down the ramp.  We drove it all over the campground. By the end of the weekend other guests were asking us if there was a place nearby to rent one.  Makes camping in a large camp like that on a lot easier.  I would think as long as your trailer had a ramp and had enough length you could haul both horses and an RTV at the same time.  For a slant load just remove the dividers and if you have a stock type its even easier.
perk2754
Reg. Oct 2007
Posted 2008-07-22 1:52 PM (#87921 - in reply to #85564)
I haven't noticed anyone mentioning a 2+1 trailer that is designed for either a 3rd horse or a cart of some sort.  I looked a Merhow model the other day at HorsePro trailers and it looks like a great configuration.  The partitions can also be moved to make two big box stalls.  There is a ramp into the front section which allows carts to be driven up.
Posted 2008-07-22 2:35 PM (#87927 - in reply to #85564)
(Quote DAVE)  Great input.    The stock combo with a center swing gate makes the most sense for my use.  Tough to find those with a drop ramp though.
rattler
Posted 2008-07-22 2:58 PM (#87931 - in reply to #85564)
The field trial world has an abundance of stock combo trailers with the side ramp. Most all are custom built trailers with living qtrs or tack up front, mid section with a big side ramp for ATVs, dogs, feed, hay, and all manner of stuff,...then a door on the opposite side of the midsection(opposite the ramp) in order to maximize air flow through the dog compart area...the rear is for the horses with a swing gate back to the midsection. Once at the field trial, horses come out and the entire midsection and horse section is opened up for use. In a 20 ft trailer, I routinely haul 3 horses, 1 ATV, 12 dogs with a 4ft dressing room.
Posted 2008-07-23 1:27 AM (#87988 - in reply to #85564)
Here's another possibility...
http://www.power-trac.com/uvclass.htm
