Tow Vehicle for a GN Trailer
PRC
Reg. Jun 2008
Posted 2008-06-05 11:26 AM (#85254)
Subject: Tow Vehicle for a GN Trailer
I just purchased a Exiss 307 Alum GN 3H with LQ, 7'W x 30'L.  Now I need a tow vehicle. I do not expect to tow that often, some short weekend getaways maybe a few time a year if I'm lucky and only 1 long trip per year 500+ miles each way. I am considering an F250 4x4 super cab, 8' bed. But the question is engine choice (5.4L gas or diesel).  Has anyone towed this vehicle with a F250 5.4L?
This vehicle will be a daily commute the rest of the time.
Any other suggestions?
genebob
Reg. Nov 2007
Posted 2008-06-05 11:36 AM (#85255 - in reply to #85254)
Subject: RE: Tow Vehicle for a GN Trailer
I would not even consider the 5.4! A lot of people on here will tell you to get the diesel, but for the miles you will be towing you should seriosly look at the V10. Also with that big of a LQ you should also consider a dually. Look at all the options. Good luck.
muleskinner
Reg. Dec 2005
Posted 2008-06-05 4:21 PM (#85270 - in reply to #85254)
The 250 super duty with V10 is ok,but dually with V10 would be better.
PRC
Reg. Jun 2008
Posted 2008-06-05 4:33 PM (#85271 - in reply to #85270)
I have been looking for a diesel because of towing capacity (not happy with the price of diesel fuel) but I have not been looking for a dually.
Why do you recomend a dually?
Posted 2008-06-05 6:46 PM (#85274 - in reply to #85271)
Originally written by PRC on 2008-06-05 3:33 PM
There are two major specifications to consider when selecting a tow vehicle.
Gross combined Vehicle Weight Rating or GCVWR is the combined weight of the loaded truck and loaded trailer.  Don't exceed this.
Axle weight ratings.  Both the front and the rear... A LQ trailer puts a lot of weight on the truck... full tanks of water, propane, furniture, etc.
rose
Posted 2008-06-05 7:39 PM (#85275 - in reply to #85254)
10005001002525
An Exiss 307 should only be about 24' on the floor. A 3/4 ton truck will do fine....Personally unless it is needed, I would leave off the 4x4. The 5.4 l engine is a good engine but not adequate for pulling imo. I had that engine in a 150 4x4 and it had a hard time handling my stock trailer with 3 horses in it. The diesel engine will last a lot longer but with the squirrely prices I agree with the v10.
genebob
Reg. Nov 2007
Posted 2008-06-05 8:31 PM (#85277 - in reply to #85254)
Originally written by PRC on 2008-06-05 11:26 AM
I just purchased a Exiss 307 Alum GN 3H with LQ, 7'W x 30'L.  I'll be honest, I'm not familiar with the Exiss 307. I assumed his 30' length was on the floor. But even if it is only 22' on the floor that is still a lot of weight on the hitch assuming an approx. 8' sw LQ.
Swill Keller
Reg. Jun 2008
Posted 2008-06-05 9:08 PM (#85279 - in reply to #85254)
I think you should check the weight of your trailer before you purchase a truck. I have been checking the towing guidelines (on internet) for the 2008 Silverado 2500/3500 and the 2008 Ford 250/350. The newer trucks cannot pull as much as the older models. My 2003 Silverado 2500 diesel with allison transmission can tow almost 15,000 lbs (I saved the towing guide from when I purchased it). The new models cannot unless you buy one ton or 3500 with diesel, as gas is still rated too low.
I do know that my truck is at its maximum with my 14,600 lb trailer but does haul the trailer comfortably.
If you purchase a new truck, check that you have E rated tires and they are properly inflated. Trucks appear to be reasonably priced right now and you should be able to get a good deal on one. There are many listed in horsetrailerworld.
Hope this makes sense and is helpful to you.
crowleysridgegirl
Reg. Apr 2005
Posted 2008-06-06 6:47 AM (#85293 - in reply to #85275)
2000500100
I might leave off the diesel engine,but,pulling a trailer that size,I wouldn't leave off 4X4.First time you try going up a hill with anything besides pavement,unless you get a heck of a run at it first,you'll wish you had it.We tried it with a 3/4T and we did not have a trailer anything near the size of our LQ.It would slip pulling a BP on the right terrain.Ask Hosspuller if you don't believe me.
Posted 2008-06-06 5:42 PM (#85314 - in reply to #85254)
The more options you have on the truck, the less weight it will be rated to tow.  It's simple math. A Crew Cab, Long Bed 4x4 weighs more than regular cab, short bed 4x2 truck. Both trucks equipped witht he same engine and trany will have the same GVCW. Subract the weight of the truck from the GVCW and thats how much your trailer can weigh.
I don't know about the GM or Dodge trucks, But the ford trucks did not change their tow rating. ( F250/350 Crew cab, 4x4 auto =15,700lbs.
I tow a 4h with a 8' shortwall LQ with my F350 CC 4x4.  My trailer has a 26' floor. When I've gone across the scales fully loaded. My truck front axle is under, my trailer axles are way under their rating. But my truck rear axle is right at or just barely over it's rating and my total GVCW is right at it's max rating. Luckily I don't usually load 4 horses, My wife and all the kids plus camping gear every trip. So I'm usually under it's rating. But I will buy a dually the next time I buy a truck unless I downsize the trailer before then. And as more of my daughter leave for college, there is less need to have such a large trailer.
Bottom line. A F250 will be able to tow the trailer. Your GCVW will probably be OK. But your trailer may push the F250 rear axle over it's limit. The F350 gives you a little higher rear axle rating. And the dually bumps it substaintially. An F350 or a dually cost so little more than the F250.
flyinghfarm
Posted 2008-06-06 7:36 PM (#85318 - in reply to #85254)
1000100100
I like pulling with a dually due to the fact it just feels more stable, nothing like going down these steep twisting Ozarks with the feeling your trailer wants to push laterally a tad.... I like the 4x4, like CRG, cuz you need it to climb some of these steep washboard loose gravel hills...!
Posted 2008-06-06 9:14 PM (#85324 - in reply to #85254)
RANT ON
OP...don't take this wrong, because your post is just the last of many on this forum with this question...but I am fascinated by people who buy large trailers and then try to go cheap on the towing vehicle...
And you have used the same statement that many of the others have said...OH, I plan on this being my daily use vehicle, so I want GREAT FUEL ECONOMY...
HORSES with LQ TRAILERS are EXPENSIVE!!!
And in the current economy...DOUBLY SO!!!
But if you cut corners on your tow vehicle...you will find out JUST HOW EXPENSIVE those savings could be...
RANT OFF
rose
Posted 2008-06-06 9:47 PM (#85328 - in reply to #85254)
10005001002525
CRG of course you are right about the 4x4....and we have 4x4 on both trucks so.... and we have diesels....
Posted 2008-06-07 12:44 AM (#85340 - in reply to #85324)
Originally written by PaulChristenson on 2008-06-06 8:14 PM
RANT ON
RANT OFF
Simply:  Well said ... Plus one
Edited to save bandwidth..
Edited by hosspuller 2008-06-07 12:47 AM
PRC
Reg. Jun 2008
Posted 2008-06-10 8:24 AM (#85454 - in reply to #85270)
Muleskinner,
Do you have a truck with the V10?
If so, how is it and what kind of milage could I expect?
I found an F350 dually with a V10 for sale but I am not familiar with the engine.
muleskinner
Reg. Dec 2005
Posted 2008-06-10 12:55 PM (#85473 - in reply to #85454)
I have a Dodge diesel,but my buddy has a V10 F-250 super-duty,Auto.It pulls a 4 horse,non LQ. sundowner.he claims 9/10 mpg. at 65 Mph.He's not the type to exaggerate.My dodge Dually gets 12/14 pulling 3 horse silver star,non-LQ.
genebob
Reg. Nov 2007
Posted 2008-06-10 2:30 PM (#85475 - in reply to #85254)
PRC- I have a 350, V10, CC, SB and pull a 4H with 6' LQ. I have all the power I need. I probably pull a lot like you expect to. It is the designated horse puller, but is also the proverbial family vehicle. How you drive will make A LOT of difference for fuel economy. I tend to be fairly light footed and will go 65 rather than 70 mph, but for general use I will get around 15 mpg without the trailer. With the trailer it will be around 9-11 mpg depending on the terrain. I had a lot of people try to tell me to buy the diesel for power and fuel economy, but unless you are putting 50,000 miles per year on will it pay off. Even if you get 50% better mileage, you still have a $7,000 engine to pay for. I have been happy with my V10 since 01 and plan to keep it. It's a good engine, and you don't have to listen to the rattle or worry about the recent problems Ford has had with their diesels lately.
NorCal
Posted 2008-06-10 6:17 PM (#85485 - in reply to #85254)
Just to add to he confusion, I have a '99 and '02 Dodge diesel pickups.  I tow my 3H gooseneck (Trails West Classic, warmblood package) with the '99 as I have not put the hitch in the '02 yet.  Believe it or not, I get 15 - 17 mpg towing and 20 or better unloaded.  I have put and Edge chip in the '99 since it does have less power than the '02, but I cannot complain about the mileage and towing capabilities.  Where the gas engine (I don't care how many cylinders it has) runs out of power is pulling grades or heavy loads as it just does not have the power curve, or torque of the diesel.  I agree that with the aqdded cost of the diesel engine, you have to keep it a ong time or really use it to pay for itself and the diesel fuel is more (go figure?) than gas.  If I was going to consider buying a diesel truck, I would seriously look for a Dodge and see if I could find a 2007 with a 5.9L or look for a 2005 - 2006 with the 5.9L.  ALL 2007 rigs with the new engines and smog are having various problems and poor fuel usage.  If you look at the fuel cost of the big block gas engine and compare that to the diesel mileage, you may be pleasantly surprised.  Bottom line, neither are cheap, but for towing / hauling, I vote diesel.
coltaffyjo
Reg. Apr 2007
Posted 2008-06-11 5:24 AM (#85497 - in reply to #85254)
I borrowed a friends v10 once and about cried when it got 4 miles to the gallon while pulling my trailer compared to my diesel that gets 12 while pulling. That means I can travel 3 times longer instead of having to pull over and refuel......... the 5.4 is a nice engine to pull with-- I prefer the diesel for better MPG.....Best advice I can give ya......borrow freinds trucks and pull with them and see what ya like.........
chadsalt
Posted 2008-06-11 7:23 AM (#85498 - in reply to #85497)
1000100100100100
Originally written by coltaffyjo on 2008-06-11 5:24 AM I borrowed a friends v10 once and about cried when it got 4 miles to the gallon while pulling my trailer compared to my diesel that gets 12 while pulling. That means I can travel 3 times longer instead of having to pull over and refuel......... the 5.4 is a nice engine to pull with-- I prefer the diesel for better MPG.....Best advice I can give ya......borrow freinds trucks and pull with them and see what ya like.........
4 mpg ????? Was that normal for your friends truck? Sounds like it was sick to me. How big is your trailer?
PRC
Reg. Jun 2008
Posted 2008-06-11 8:44 AM (#85503 - in reply to #85475)
Genebob,
Thank you!
Great info, I plan on going to see a used 05, F350 V10, 4.30 DRW Sat.
I was trying to stay away from the dually for daily parking issues (tight lot at work) but it seems people say it makes a difference.
I am also suppose to see a F250 sc lbed diesel SRW.
Hope to find a good deal since the price of fuel.
Thanks again to you and others for the great info!
Edited by PRC 2008-06-11 8:54 AM
liv to ride
Reg. Jul 2007
Posted 2008-06-11 9:08 AM (#85508 - in reply to #85254)
For what it is worth I'll add my two cents. I had a 4-horse 12' sundowner that I pulled with a 2500HD Chevy Duramax single axle. The truck had airbags and excellent tires. The engine handled the load fine, but I will say that my husband told me he prayed alot every time I left the driveway. Before all you people say" Boy that was dumb" I already know that,but I hated the thought of driving a dually. To make a long story short I now own a 3500CC Duramax Dually and I couldn't be happier. I wouldn't have believed the difference the duals made until i actually drove one pulling the trailer. First thing I did was tell my husband he was right. Made his day. I absolutely love my Duramax, Tons of power,extremely comfortable ride, and I also get decent mileage pulling a trailer. Plus I don't think you can beat the combination of the duramax engine with the allison transmission. Also I live in Montana so I know what its like to pull a grade with a load. Hope this helps Good luck
reinergirl
Reg. Feb 2007
Posted 2008-06-11 11:00 AM (#85520 - in reply to #85254)
I have had both. My first truck was an 01 F350 V10 CC SRW. I had plenty of power but my trailer (315LQ) was definitely not as stable as it is with a dually. I moved from the 01 to an 04 F350 CC DRW diesel and have never looked back. For the first two years it was also my grocery getter. I would definitely recommend the dually over SRW.
genebob
Reg. Nov 2007
Posted 2008-06-11 11:10 AM (#85522 - in reply to #85254)
I do not expect to tow that often, some short weekend getaways maybe a few time a year if I'm lucky and only 1 long trip per year 500+ miles each way.Yes the duelly will give you more stability. But the OP was originally asking about using a 5.4 engine and still using it as a daily driver, in New Jersey no less. Hard to compare driving and parking a duelly from Montana to New Jersey. For most of us having the biggest truck we can find is totally not practical.PRC- I've got the 3.73 rear end and it works fine for me.
Tresvolte
Reg. Feb 2008
Posted 2008-06-11 11:35 AM (#85527 - in reply to #85254)
Maybe this will help you a little. It is another link with the same question that you have. By the way...according to Exiss website your trailer will weigh about 6600 empty.
http://www.rv.net/FORUM/index.cfm/fuseaction/thread/tid/20693735/gotomsg/20694149.cfm
liv to ride
Reg. Jul 2007
Posted 2008-06-11 4:37 PM (#85542 - in reply to #85522)
Well it wasn't the biggest truck i could find, and i just don't drive it in Montana. I have also driven in Seattle traffic, minneapolis traffic,Dallas, Oaklahoma City and Denver. My trucks also do double duty as grocery haulers. They are my everyday vehicle when not pulling a trailer, but to get back to your original question no I don't think that the 5.4 engine is big enough for what you want to do. Nothing scarier than being under powered when pulling a trailer. Enough said
PRC
Reg. Jun 2008
Posted 2008-06-12 8:04 AM (#85559 - in reply to #85254)
It seems the opinions are V10/ 8.1 (large gas)  or diesel.
The next option I have to figure out is SRW or DRW? (I may test drive one, bring it to work and see if I can park it.)
My trailer is a 2004 GVWR: 9995
The new trailer is GVWR: 10800
So if my trailer is about 6k lbs + 3 horses @ 1k ea (small horses 14.2 - 15.2) + gear and tack I am into the 9,000 lb range.
Which puts me at the limits of a small gas engine so large gas or diesel makes sense.
Edited by PRC 2008-06-12 8:11 AM
Posted 2008-06-12 8:48 AM (#85561 - in reply to #85254)
I haul a heavier trailer than your proposed #10800 with a SRW truck. There are no stability issues that would want me to switch to a dually. I don't have the indoor storage space for a DRW, don't want to buy the extra tires or spend the extra gas dragging them around. I am very satisfied with a SRW truck as a tow vehicle.
A good friend of mine has a similar truck  except he has the v10 gas. He's retired and picks up extra money shuttling and delivering RV trailers for local dealers using a fifth wheel. His truck is also used for daily travel, mine is only used for hauling. We both discussed at some lengths, the pros and cons of gas vs diesel before we ordered our trucks. He chose gas, I chose diesel. We both have a 4X4 CC with a full bed. We both are pleased with our decisions
We live in a mountainous area of western PA, which has a few grades of 7% and 11%, but not nearly the lengths of the inclines found by the western US inhabitants. With my diesel, I chose the 373 axle ratio, with his gas, my friend chose the 410. Both work well.
You have to decide which is more important to you, daily transportation or hauling. Either truck, A SRW or a dually will do both, but your comfort and expenditure levels will vary depending on your choice.
The area in which you live and its topography, your daily commute and parking concerns, and the extent of your towing, will all vary from the truck owners who have previously given you their choices of vehicles. You have to determine what is best for you.
PRC
Reg. Jun 2008
Posted 2008-06-12 10:06 AM (#85574 - in reply to #85561)
Gard,
Sounds like go for the bigger engine (gas or diesel) and SRW's are ok.
Thank you!
genebob
Reg. Nov 2007
Posted 2008-06-12 10:58 AM (#85576 - in reply to #85254)
That's been my point all along. Good idea to test drive both vehicles, and if possible pulling your trailer. I realize that may not be possible if they don't already have the GN ball in them. Like I said my truck is a 350 CC, SB, SRW. My trailer is heavy enough that I was dropping about 2 1/2" so I put air bags on this winter and they make all the difference in the world. Good luck and have fun with whatever you purchase!
PRC
Reg. Jun 2008
Posted 2008-06-17 7:22 AM (#85793 - in reply to #85561)
Gard,
Are you towing horses in the trailers?
Wondering about DRW because of live weight?
PRC
Reg. Jun 2008
Posted 2008-06-17 9:10 AM (#85798 - in reply to #85324)
RANT ON,
Sounds like you didn't read what I wrote before you ranted. "cheap on the towing vehicle..." and "I want GREAT FUEL ECONOMY" only appear in what you wrote.  I was questioning towablility.
I was looking for educational real world experience as other members have posted.
Edited by PRC 2008-06-17 9:39 AM
Posted 2008-06-17 9:22 AM (#85801 - in reply to #85254)
Both of our trailers have a three horse capacity, in which we commonly carry two horses. The third stall is used for storage. We have, on occasion, hauled a third horse, but that is not a common occurrence.
We have installed Timbren aux springs on our truck, which ensure a level ride. We have not had any towing difficulties due to a lack of power or stability. We can tow at any highway speed that we can afford, with the air and cruise on. We've been in many conditions of high cross winds with no adverse affects; passing or oncoming trucks have no influence.
One area that should be mentioned is when using a truck camper. We had several and ended up with a 10' model that was the reason we installed the Timbrens. Without them, the truck should have been a dually, for it was top heavy and adversely affected by cross winds. After the aux springs were installed, most of these conditions were eliminated.
With my rig, I am comfortable towing up to about #12k in weight. I did tow a larger trailer for a friend, and while it towed well, I could definitely feel the difference on the back of the truck. The rear tires were overloaded, and it would have been unsafe to go any distance. He has a dually, and it is apropos for his usage.
Everyone has his own needs in the way of proper equipment. What may work for me, may be insufficient for another horse owner. You have to determine what your requirements are, and buy accordingly. Bigger is not always better.
PRC
Reg. Jun 2008
Posted 2008-06-17 9:32 AM (#85806 - in reply to #85801)
Gard,
Thank you for the great educational information!
Your tow vehicle is a F350, CC, 8'bed, 4x4, diesel, SRW with 3.73?
PRC
Reg. Jun 2008
Posted 2008-06-25 2:28 PM (#86342 - in reply to #85293)
Can you leave off the 4x4 if the truck has DRW?
genebob
Reg. Nov 2007
Posted 2008-06-25 3:03 PM (#86350 - in reply to #85254)
In snow or slippery conditions, the duals will actually be worse. My father-in-law and I just finished hauling corn to market, we were both using identical 650 bushel wagons. I was pulling with my 01-F350, V10, CC, SB, SRW, 4WD. While he was pulling with his 2000 Chev 3500, CC,LB, DRW, 2WD. He had to put 500 lbs weight in the back so he could get traction at the start. Only a few times did I even need the 4WD. I would choose the 4WD over the duals if you need to make the choice.
Posted 2008-06-25 3:16 PM (#86354 - in reply to #86342)
Originally written by PRC on 2008-06-25 1:28 PM
Dual rear wheels are for weight carrying.  4x4 is for traction in slippery road conditions. The two options are not interchangeable
Posted 2008-06-25 4:29 PM (#86361 - in reply to #85254)
In my part of the country you cannot own a tow vehicle without it being a 4x4, dually or SRW.
statzk
Reg. May 2006
Posted 2008-06-25 4:34 PM (#86362 - in reply to #85254)
I know a couple people who have DRW 2WD tow vehicles. I know both wish they had gotten 4X4 and will in their next vehicle.I know I wouldn't buy a truck for towing without 4X4. I didn't want a dualie, and am very happy with my choice of 2500 QC 4X4. :-) Granted I don't tow a monster trailer (even our new one is only 10K GVWR), so the choice of 2500 was best. If Dodge made one and I had the chance I would have looked at SRW 3500s.Cheers!~K
Tony_V
Reg. Jun 2008
Posted 2008-06-27 8:55 AM (#86497 - in reply to #85793)
Originally written by PRC on 2008-06-17 7:22 AM
Gard,
I am researching information to help me with my next truck purchase. This is the first time I've run across the mention of "live weight". Is this a consideration for choosing between SRW and DRW? I am leaning toward a SRW configuration but my load estimates are only a few hundred pounds below the capacity of SRW. Should I be considering DRW due to this live weight?Tony
muleskinner
Reg. Dec 2005
Posted 2008-06-27 11:00 AM (#86506 - in reply to #86362)
Originally written by statzk on 2008-06-25 4:34 PM
The only difference between the Dodge 3500 SRW and the Dodge 2500 is Overload springs and cab-lights. The 03 3500 SRW truck I owned was rated 9900 GVW so a few extra lbs. of payload or tongue weight.,it was a great truck,I towed with it for 155,000 miles with zero problems and then traded for a duallie,wish I had it back now.!!! It ould be payed for.
PRC
Reg. Jun 2008
Posted 2008-07-11 10:11 AM (#87277 - in reply to #86361)
I finally bought a horse truck! (Thank you all, for all your help and advice!)
Any recommendations for the hitch?
Turnover, Popup, FlipOver?
The Popup looks interesting.
Edited by PRC 2008-07-11 10:13 AM
Tresvolte
Reg. Feb 2008
Posted 2008-07-11 1:09 PM (#87295 - in reply to #85254)
Congrats on the new truck.
B & W Hitch. It is a turn-over. Best on the market.
