Installing Laminate floor in trailer?????
Mandi/Abby
Reg. Sep 2003
Posted 2008-05-09 3:47 PM (#83601)
Subject: Installing Laminate floor in trailer?????
Charter Member
I tore out the old carpet, put down foam insulation stuff and then put OSB on top of that. I'm going to use laminate for my flooring. Do I need to put anything between the OSB and the laminate?
TERP
Reg. Sep 2006
Posted 2008-05-09 10:19 PM (#83626 - in reply to #83601)
Subject: RE: Installing Laminate floor in trailer?????
You just need the pad that comes with it. There is normally 3 kinds. Get the 2 in 1 foam pad, unless the floor that you are buying has the pad attached, then you are all set.
Mandi/Abby
Reg. Sep 2003
Posted 2008-05-10 7:46 AM (#83639 - in reply to #83601)
Charter Member
Its got a thin pad...is that what you mean?
TERP
Reg. Sep 2006
Posted 2008-05-10 2:33 PM (#83662 - in reply to #83601)
Yes, that is correct.
