Need educational link on tire Ply / Load Ratings.
Sharon
Posted 2008-04-28 11:22 AM (#82732)
Subject: Need educational link on tire Ply / Load Ratings.
My new 5000# GN has Goodyear tires... 15" trailer tires, load range D, but only SIX PLY and they're also RADIALS.  I knew this when I bought it and just figured I'd replace them.  The thing is, based on the markings on the tire they're FINE... loaded, the trailer is still only around 7000# and each tire is rated for something like 2150#.
SOOOOOOOOO, can anyone post a good educational website with info about TRAILER tire load ratings and ply choices?
Thanks!!
chadsalt
Posted 2008-04-28 11:50 AM (#82734 - in reply to #82732)
Subject: RE: Need educational link on tire Ply / Load Ratings.
1000100100100100
http://www.goodyear.com/rv/faq/load.html
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=55
Ply, load range, max psi dont really mean anything.........the actual load capacity (at specified psi) will be stamped on the tire, that is all that matters. Sounds like you have ST205/75/R15 ?
Nothing wrong with radials, your tires are fine.
Posted 2008-04-28 7:23 PM (#82754 - in reply to #82732)
As Chad said, I would not worry about the ply, but more importantly what weight they are rated to carry.
Your load rating is a combination of the tires, wheels, axles, springs and what ever weight that sits on the hitch.
If your trailer is a GN and has 25% of its weight resting on the Gooseneck Hitch.
7000lbs  * 25% = 1750 lbs on hitch
7000lbs * 75%= 5250 lbs on tires.
4 tires at 2150 lbs each = 8600lbs total. So your loaded trailer at 5250# is well within the limits of the tires.
If it's a bumper pull with 600 lbs on the hitch leavng 6400# on the axles and you are still well under the max.
Your "D" rated tires are typically rated at 65psi.  A "E" tire will usually run at 80psi. A "G" rated tire runs at 110psi.
Buying a higher rated tire may let you hold higher pressure, But that doesn't mean your rims will hold the extra pressure. I definitely would NOT put a "G" rated tire as a replacement on a rim designed for "E" rated tires.  Somebody may just read the label on the tire and not look at the rim and put 110 psi and blow the rim to pieces.
Sharon
Posted 2008-04-28 8:43 PM (#82761 - in reply to #82732)
Thanks, both of you!    I looked at them again this afternoon and they're actually rated at more than 2500# each... even better!  I'll just double-check for myself that they're inflated to 65psi like they're marked... they look soft to me even though the shop said they did it.  (Oh... someone told me today that the ones that say 65psi are usually 8 ply.  I need to look at them again and see what it says on there.)  Thanks again!
