| I want to add a awning to my Exiss. I have checked various rv sites but none of them show the mounting hardware that mount to the trailer. I will need a curved piece for the top bracket. Any suggestions? |
Location: Springtown, Texas | I just had an awning installed by Camping World. They used a radius awning mount bracket from Dometic (component parts) # 3108907.027. Camping World's sku was # 0509. Best of luck. |
 Location: Decatur, Texas | CAMPING WORLD ALL THE WAY! FYI, if you are wanting a good awning for the money go with the standard awning, not the 2 step! I had the 2 step and remove it to install the standard! The 2 step can not be used in the wind at all and the standard can be! |
  Location: Elgin, IL | just how much do the awnings run? |
    Location: Vanzant, Missouri | maybe this will give ya some ideas. I have this brand on my Exiss....Mine is a 15ft awning... http://www.rvawningsonline.com/ |
 Location: Alpine, AL | Can someone please tell me what the difference is with the awning types? 2 step vs manual? thanks, Kim |
    Location: Vanzant, Missouri | The TwoStep™ awning allows you to simply unlock it, lower and enjoy. The TwoStep™ requires no lifting, no knobs to twist or rafter to slide. Basically just a fancier awning..With the manual you unlock it, lower it, adjust the rafters on it... |
