Electrical-Fine Yesterday-Wrong Today
walkin
Posted 2008-04-05 11:51 AM (#81259)
Subject: Electrical-Fine Yesterday-Wrong Today
500100
Cleaning up trailer yesterday.  Showing correct electricity in outlet checker.
Today-Hot and Ground Reversed.
Same cord, same adapter.  Changed cord ect, still wrong.  Hit curcuit breakers and they wer'nt tripped.
Outlet showing correct, both yellow lit.  Hit ground fault breaker and still no change.
walkin
Posted 2008-04-05 1:26 PM (#81262 - in reply to #81259)
Subject: RE: Electrical-Fine Yesterday-Wrong Today
500100
Never mind--Fixed It!
Posted 2008-04-05 2:48 PM (#81266 - in reply to #81259)
1000500100100100252525
Posted 2008-04-05 3:00 PM (#81268 - in reply to #81259)
Soooooooo! What did you have to do to fix it!?
walkin
Posted 2008-04-05 4:01 PM (#81276 - in reply to #81259)
500100
Somehow the ground fault breaker outlet in the kitchen area was tripped.  But does that make sense-- ??
I hit that and then tester showed OK.  I thougt if the ground fault breaker tripped--it would shut off electric to that particular outlet.
Posted 2008-04-05 4:46 PM (#81278 - in reply to #81259)
If we trip a ground fault in our master bath, then none of the other ground faults in the house will work. Kitchen and the other bath will be dead also, along with the outside recepticles... Not really sure how all that works.
walkin
Posted 2008-04-05 5:30 PM (#81279 - in reply to #81259)
500100
Yes. Once a GF breaker trips all is dead.  This was showing hot ground reversed what ever the red on the left and the yellow on the far right of the tester.
wyndancer
Reg. Apr 2007
Posted 2008-04-05 7:44 PM (#81285 - in reply to #81259)
A GFCI can be wired two ways, one in which the GFCI is the last outlet in the electrical run, and therefore it is the only outlet that is protected. Or it can be wired the first in the electrical run and those outlets that follow it are protected.So in a home, the outlets on say a deck or patio are protected, but they may not have the test/reset buttons on it. And you may find that the GFCI outlet is in an upstairs bathroom, or in the garage, or in the utility room. Electricians can get creative with the wire runs sometimes.
Posted 2008-04-06 8:28 PM (#81340 - in reply to #81285)
Originally written by wyndancer on 2008-04-05 8:44 PM
Actually there is a third alternative of wiring options, where each GFCI outlet protects itself and nothing else on the circuit...
