| Hi all- I was looking at Trailer Life's 1999 tow ratings on the Ford Expedition. I'm a little puzzled as to this comment on the 5.4L 4WD rating:
Expedition 4WD 5.4 V-8 7,900a,d Expedition 4WD 5.4 V-8 7,400a,d,m
In the key below, a = automatic transmission and towing pkg, d = Requires 3.73:1 axle ratio, and m = Requires 17-inch wheel option.
So - standard wheels on the Expedition are 16", and I'm assuming the first rating of 7900 is applicable to those. How does having larger wheels lower the towing capacity by 500 lbs?
Edited by classact2575 2008-04-02 3:41 PM
      Location: Rocky Mount N.C. | The 16" wheel is running "LT" tires (LT265/75R16lrD) and the 17" wheel is running "P" series tires (P275/70R17)...17" Passenger tires verses a smaller 16" light truck tire which has a higher load capacity. That's just my S.W.A.G. |
     Location: sc | Basically what retento said.......although I doubt it comes standard with LT tires even on the 16". It usually has to do with the construction of the tires, the larger rim size having small sidewalls and such. |
       Location: western PA | Our Expedition had the "P" tires on 16" wheels. Gard |
