  Location: IN | How can I find out what kind of springs, brake drums, etc. my 1999 F250 Super Duty has? I bought it used and the person who owned it before me used it to haul a big boat, not a horse trailer. I'm using it for my 2 horse GN (soon to have)LQ. I assumed the F250 would have enough power etc. to easily haul around a fully loaded rig like mine, but after reading posts about the difference in springs, shocks, etc., how can I find out that info for my particular truck? It's a 2WD gas engine, extended cab, short bed, if that helps? Any resources out there where I can look up the specs on my particular truck? Thanks! |
     Location: Tennessee | Get your vehicle info by using this VIN decoder:
https://www.fleet.ford.com/maintenance/vin_tools/default.asp
Look on page 136 in this manual here for towing specs:
http://www.motorcraftservice.com/pubs/content/~WOXF23/~MUS~LEN/36/9...
Edited by Towfoo 2008-03-11 7:49 PM
  Location: IN | okay thanks. Those were both helpful websites, but still didn't provide the specific info on my truck. What I think I've determined though is that it has a GVWR of 8800 and a rear axle ratio of 3.73. I just want to be sure I can pull my 2 horse gooseneck with 4' LQ around pretty easily fully loaded. I'm thinking of taking a camping trip to the Smokies this spring and and my friend and I both have 16H quarter horses. I want to make sure I won't have any problems going up and down mountain roads fully loaded. Guess I can talk to a mechanic, but around here, most of them don't really understand hauling horses...a trailer's a trailer to them. Some of them can get pretty condescending and dismissive to a "girl". Thanks again! :) |
       Location: western PA | Originally written by Dunagain on 2008-03-11 7:28 PM
How can I find out what kind of springs, brake drums, etc. my 1999 F250 Super Duty has?.I assumed the F250 would have enough power etc. to easily haul around a fully loaded rig like mine, but after reading posts about the difference in springs, shocks, etc., how can I find out that info for my particular truck? It's a 2WD gas engine, extended cab, short bed, ! What gas engine do you have? V8 or V10? The 5.4 in the SD would be underpowered in most mtns while pulling a rig. You have 4 wheel discs, and while using electric trailer brakes, you'll have all the braking capabilities you'll need. The SD has a hefty frame, rear axle and suspension, enough to haul any two horse trailer. My only consideration would be the power factor on the hills. A copy of the owner's manual will give you all the specs you need if you can't find them on the internet or the service desk of your Ford dealer. Gard |
  Location: IN | Thanks Gard! I have the 5.4L v-8 so it's good to know where I stand at least. I've noticed a little under-powered-ness on some of the "hills" in southern Illinois/Indiana. Hmmmm....I was always told that a 3/4 Ton Ford would be more than enough for my needs. Guess those guys didn't really figure what "my needs" were going to be....ahem....story of my life! (wink!) ;) Thanks again! |
 Location: West TN | I agree with Gard on being somewhat underpowered. I have owned a Ford 5.4, V-10, and a three 6.0 diesels. Each engine certainly has its advantages and disadvantages. You will just have to be considerate of the engine power you have while towing. I pulled a 16 ft gooseneck with three horses a few times with a F150 that had a 5.4 and I knew it was back there when I reached the hills. I upgraded to a V10 and I knew the engine was there when I passed the gas stations. Most people think that the F-250 will have the diesel in it when they make the statement that it should pull whatever you want. You certainly have enough truck with regards to frame and suspension to pull what you want. Just make sure you pay close attention to your driving and you should be make it. |
     Location: Tennessee | How much does your 2 horse GN trailer with living quarters weigh? If it's over 7000 lbs you probably don't have enough rated towing capacity. |
       Location: western PA | Dunagain, I didn't mean to imply that your truck won't work for you because of its smaller engine; it will. I just meant that while towing in the mountains, you probably will not be able to maintain the posted speed limits. That's why they invented passing lanes. When you're under a load for a length of time, you have to get a feel for the drive train. Don't just floor the accellerator and try to make the truck go as fast as possible. After the transmission downshifts and the motor accelerates, you will get into a range where you will want to back off on the throttle. The truck will be "more comfortable" in a slower rpm range and not running as loud. It will sound less stressed and be pulling easier. Watch your coolant temperature, and if everything is normal, that's a good speed to maintain. Your tack will probably be around 4k + or so. Your engine is an overhead cam design, which means that it's efficient, and make its power at somewhat high rpms. When pulling hard, go by the engine rpms and engine sounds, not by your speedometer. Your SD is built for heavy work, and if treated well, should last you a long time. If your mountain driving only involves a small percentage of your total driving, your truck should suffice well. Make sure your cooling system has new coolant, the transmission has a new fluid flush and filter, and your engine has the best oil you can buy, preferably synthetic. A new air filter and fluid check of the rear axle, air your tires, and you're ready to go. You have a good truck, enjoy it. Gard Gard |
  Location: IN | Thank you Gard...and everyone. This forum is awesome because I get the info I need to either make educated decisions or head in the right direction to get more info. Thanks for the "slow down" scenario because that is exactly what I was experiencing on this one long hill on the highway in southern Illinois. The truck would start up the hill at 60-65 mph, and then it would start slowing down about half way up. I, of course, would floor it, but it didn't seem to do much ...which made me worry. I do watch the RPM's and it will switch from about 2.5 to just over 3 when put to work. I worried because that was happening on a rather "minor" hill with only one horse and no weekender package. If I can count on it making it up the hill, but just at a slower/consistent pace, I'll feel better. No, not much mountain driving, but I'd like to travel to further places (TN, SD etc.)now that I have a comfortable place to sleep. Once again HTW members...you guys are awesome! (insert clapping smiley guy here!) |
