    Location: Roanoke IL | Last summer my mare managed to rub out a whole section of her mane that draped down past her neck. She looks terrible, it has only partially grown back this winter. What can I do to keep her from rubbing it this spring? I've used medicated shampoo, tried conditioners, tried NOTHING, and she still rubs it. I've tried shapleys MTG, I've tried lysterine. I can't see any real reason why she'd itch just that ONE spot so badly. Any ideas? She used to have such a pretty mane...but not anymore. I'd like to know what the best spray on conditioner is....it seems that some make the hair slick, but leave it dry and brittle. Amanda |
.jpg) Expert
      Location: Southern New Mexico | How are your fences? Is there anything interesting on the other side? I'm only asking because my filly did this last year but she was trying to get at the hay that was in my old mares pen and was rubbing the same spot while trying to reach between the bars of the pen. She had the mane/hair rubbed off down to the skin. I had to put welded wire up to keep her from sticking her head through the bars to fix the problem. Two of my other horses have done the same thing so now there is wire between all of my rails. |
   Location: Danielsville Georgia | I've got a gelding that did his mane and top of his tail for two summers now.Never before.Tried all kinds of products to no avail.Open to suggestions. Even took skin samples and used the mircroscope looking for critters.
Edited by hounddog 2008-03-01 4:28 PM
    Location: Roanoke IL | I suppose she could be sticking her head between the rails, but it seems usually that it's itching on the doorframe. She just rubs her head up and down and totally snarls up that one hunk of mane. It turns into this frizzy fried hairball that just breaks off in your hand. I put a board up to keep her from trying to eat through the rails, which I hope helps, but I think there must still be some underlying reason why she keeps itching that one particular spot....other than to tick me off...It would be like your car driving out of the garage and denting itself. I like my horses to look pretty, not mangey! Amanda |
         Location: South Central OK | I'd go in and have the area scraped by the vet and look for any signs of skin diseases. How often do you worm for pin worms? |
    Location: Roanoke IL | I'm not sure which wormers kill pinworms, but I rotate products and worm regularly. Every so often I'll use one of the stronger wormers (like zimecterin gold) to make sure everything is killed. I'm too scared to use Quest though. I used to until I heard about so many problems with it. It's not worth the risk in my book. Amanda |
         Location: South Central OK | Sorry Angel I wasn't clear... You need to have the vet look into the cause of the mane rubbing if you are at your wits end. (You'll be looking for a skin infection/disease that is chronic.) Tail rubbing is caused largely by pinworm infestation, this info was for the other poster. Many wormers can be used for pinworms but must be given in higher doses to be effective. When in doubt ask a vet. |
   Location: Danielsville Georgia | Did fecal.Vet did the skin exam..He stops it in cool weather.Iverrmictrin kills pinworms and are they not a easy parisite to control? |
         Location: South Central OK | hounddog, if it's only in the summer and your vet cleared him for any skin problems your cure might be super simple. Horses are very sensitive to dried sweat. *Daily* rinse his complete hind-end including under his tail (lift it up) and between his back legs (where they touch) and see if you have any changes in behavior. I've also seen in some horses that at the top of the tail head they get sunburned and due to the dried skin they'll rub. A spray on sun screen will cure this problem, along with scrubbing the peeling skin off during a bath. Admittedly I pamper all my animals... *Another thought* Horses can become chemically sensitive to some fly sprays. Try changing for a few weeks to see if the condition improves, I know an Arabian gelding (black sands lineage) that can only use Fly shield or else he comes out of his skin.
Edited by huntseat 2008-03-03 4:48 PM
     Location: Fort Worth, Tx | I would also use a flax supplement to mnoisturize from the inside out, see if that helps it grow back. Eqyss also makes a product that is designed to help hair growth if you haven't tried that one, it is a great conditioner as well. |
  Location: Helena, Ohio | You could also try tea tree oil mixed with water, 50/50 to spray on. It will help relieve the itching and help with any infection or bacteria that is there. My gelding did this same thing every year. The skin would end up looking like elephant skin!! I started the tea tree oil and it help very quickly. Now I start in about April and cintinue spraying him down about once or twice a month till November (I live in NW Ohio) and he hasn't had this issue in years. |
   Location: Coconut Creek, FL | I had good luck with dandruff shampoo, but you gotta leave it in for 10 full minutes before rinsing. |
    Location: AL | Sounds like it could be an allergic reaction to the midge as well. Also known as sweet itch/Queensland itch. So hard to control. Flaxseed has helped my guy and only time will tell how this spring/summer/fall will go. Immune system is not as strong as it needs to be is what I am told, so I am starting mine on some herbs for the immune system. This was rampant here in the south last year and hoping it won't be as bad this year. Horse is miserable, owner is miserable...... It has been a nice few months not having to worry with it!! |
