Breaker Box in LQ
Rose66
Reg. Dec 2006
Posted 2008-02-28 7:53 PM (#78258)
Subject: Breaker Box in LQ
What are the pros and cons for having the breaker box on the inside of the LQ (hidden in a boot box) versus on the outside underneath the gooseneck?
crowleysridgegirl
Reg. Apr 2005
Posted 2008-02-28 7:59 PM (#78260 - in reply to #78258)
Subject: RE: Breaker Box in LQ
2000500100
I've never seen a LQ with the breaker box outside.
flyinghfarm
Posted 2008-02-28 9:36 PM (#78268 - in reply to #78258)
1000100100
Same here.  Outside + water = makes me nervous!
greyhorse
Reg. Nov 2005
Posted 2008-02-28 9:59 PM (#78273 - in reply to #78258)
Inside you can flip the breaker back on/replace fuse without having to go out (if it trips or blows a fuse it'll always be raining, cold, or dark). And like they said it's protected from the elements if it's inside.
horsey1
Reg. Dec 2004
Posted 2008-02-29 8:44 AM (#78299 - in reply to #78258)
All true LQs I've seen used a breaker panel that isn't weatherproof anyway. And a lot of them use the combo converter/breaker assembly that has to be flush mounted in a cabinet front.
