 | Plex hose is the standard in trailers . It is easy to use and install. When it starts to freeze plex will flex or expand and not brake as easy. It will brake but it will last longer than other water line options. The flair fitting are the easist to use and work on if something goes wrong later. And after you have to buy the crimper and crimp rings the cost is about the same.
