Shavings or no?
luckeys71
Reg. Dec 2007
Posted 2008-02-18 9:16 PM (#77207)
Subject: Shavings or no?
With rubber mats on your trailer floor, is it better to put down shavings or not?  I know the shavings will help absorb urine and feces, but wouldn't loose shavings, especially over rubber, make it more slippery in there?  Just trying to decide if I should put shavings down in my trailer or not.
Posted 2008-02-18 9:53 PM (#77214 - in reply to #77207)
Subject: RE: Shavings or no?
We've found the use of shavings absorbs much of the moisture that contributes to slippery mats. We tried sawdust and were not pleased at how much of it blew around, when the windows were dropped down while traveling.
We have an industrial paper shredder. Shredded paper bedding works very well, not only for the trailer, but the stalls as well. It breaks down well in gardens, and has none of the acidic problems, found in the wood by products when used as a mulch.
I've read where feed pellets were favourably used; they became more absorbent as they are crushed.
The mats are less slippery while using a bedding, even straw. The horses are more stable and have better footing.
BOL  Gard
headhunter
Reg. Oct 2004
Posted 2008-02-18 10:28 PM (#77220 - in reply to #77207)
50010010025
I use shavings in my trailer and found it much easier to clean than without.  Just scoop out the poop and the urine area and replace with fresh shavings.  I also think it makes the trailer more "stall like" for horses that may not have much trailering experience.
flyinghfarm
Posted 2008-02-18 10:47 PM (#77223 - in reply to #77207)
1000100100
Yes, heavy shavings, absorbption, better footing, JMHO
Angelmay84
Reg. Jan 2008
Posted 2008-02-19 5:02 AM (#77229 - in reply to #77207)
Just be sure to clean it alllll out when you're done.  Don't leave it to sit in the trailer.  I had a big stock trailer, and I'd use straw for bedding because there was no hope that shavings or sawdust would stay put.  I had a horse who had some bad allergies and the shavings dust would give her the snots when we traveled.
Amanda
Posted 2008-02-19 5:56 AM (#77231 - in reply to #77207)
Shavings? YES, just spray or mist them down a bit first.
Edited by retento 2008-02-19 8:53 AM
farmbabe
Posted 2008-02-19 7:35 AM (#77241 - in reply to #77207)
1000500100100
Shavings or sawdust will only get wet and slippery if they are really soaked. unless your horse LIVES in a trailer for days at a time, mostly likely you won't have to worry about that happening.
Short trips you can manage with nothing on the mats if you prefer but really using something is ideal. I have used sawdust without probelms assocaited ( and I don't water it down) and straw ( as I have it easily available) I don't have a preference. Whatever you have on hand will do.
Posted 2008-02-19 10:44 PM (#77348 - in reply to #77207)
1000500100100100252525
I do not use shaving because the blow around and get in the horse eyes sect
barntoys4mom
Reg. May 2007
Posted 2008-02-20 11:18 AM (#77398 - in reply to #77207)
I use a course grad white pine sawdust, prayed with water if dusty, about 4 or 5 inches deep (gelding doesn't appreciate splatter if the bedding is too thin) and clean any wet areas and dirty areas down to the mat and let dry completely.
flyinghfarm
Posted 2008-02-20 12:19 PM (#77406 - in reply to #77207)
1000100100
You can use face masks if the bedding tends to be airborne, as it does when I use the 20' GN stock trailer, so I just protect their eyes, bed the trailer and clean as above.  Best of both worlds!
Posted 2008-02-20 10:27 PM (#77473 - in reply to #77406)
question, if you use a fly mask does the horse get nerviest because of the darkness, I real like the idea of the mask then I would use bedding
flyinghfarm
Posted 2008-02-21 7:17 AM (#77484 - in reply to #77207)
1000100100
The fly mask is kind of like window screen, they can see out and don't seem to be nervous in any way.  Works great to keep specks from flying into their eyes, and just works really easily and well...
Too L Ranch
Reg. Jul 2006
Posted 2008-02-21 6:51 PM (#77562 - in reply to #77207)
We bed deeply with rice hulls. Low on dust and pretty absorbent. Have never had a problem with it becoming slippery. Personal opinion is that it gives the horses more of a cushion to stand on and it is easier to keep the trailer clean.
whoaboy
Posted 2008-02-22 6:40 PM (#77644 - in reply to #77207)
No shavings unless I am going a long distance.
Towfoo
Reg. Jan 2008
Posted 2008-02-22 8:03 PM (#77657 - in reply to #77207)
100100252525
Where do you get rice hulls?
randemtam
Reg. Jun 2007
Posted 2008-02-22 8:04 PM (#77658 - in reply to #77207)
10010010010025
I use nothing for short trips. I have stock sides on my trailer and I have sawdust at home so that's what I use for long trips. I don't cover the entire floor but rather the butt section of the trailer. The hoses will kick enough under their bellies to pee in and it makes cleaning out the poo much easier. It tends to be damp anyhow because we don't keep it covered but I don't have a problem with it blowing around too bad and annoying the horses.
I don't bother with shavings in my 2 horse at all but our trips with that trailer are fairly short anyhow.
FWIW
