 Charter Member
    Location: Holland, Tx | Is it normal (or at least possible) to connect the water heater (electric) to an on/off switch so that it isn't turning on/off when not in use? Also - while looking at water heaters at Home Depot/Lowe's, I saw a "water heater pan", which the heater sets in and the pan just collects any moisture which could build up on the outside of the heater. Is this necessary? |
