 Charter Member
    Location: Holland, Tx | From what I have found, the portable generator I was looking at is a 5000watt from Onan and is rated around 76dbs. The Boliy mentioned on another thread is 3300watt and is rated around ~55dbs. How big of a difference is this in sound? I've looked at the charts comparing the generator sound to regular, everyday noises, but it doesn't help me much. |
 Charter Member
    Location: Holland, Tx | The Kipor and Boliy caught my attention, but a couple negative opinions on some website I found through Google has me concerned. Darn. I like that savings idea. |
      Location: Texas | That's a BIG difference in sound. My Kubota Diesel generator is rated at something like 69-70dB and it's pretty loud if you're outside or parked right beside someone, hardly noticeable if you're in the trailer. I would go for the quietest one you can afford if you're going to be parked near other people. |
   Location: The Land of Ahs | check out the Yamaha EF3000iSEB, rated 51 to 57 db. This one has the power boost which will start the bigger AC units out now. I have one and it's very quiet on full load and even quieter on the economy setting. It's as quiet or better than my friends 3500 Honda. Mine was less than $1900, delivered, and included the wheels and battery charging cables. I'm not a dealer, just a satisfied user on a small budget. |
       Location: Northern Utah | the old rule of thumb is, Your ears can tolerate 80dbs for 8 hours in a 24 hour period. Each 5 dbs increase cuts the time in half. ie 85 dbs for 4 hours, 90 dbs for 2 hours, 95 dbs for 1 hour and 100 dbs for 30 minutes, 105 dbs for 15 minutes, 110dbs for 7.5 minutes, 115 dbs for 3 minutes and 120 dbs for 1.5 minutes Anything more and you sustain hearing loss. 50-55 dbs is considered Normal Voice level. Most Automakers try to keep the road noise in their vehicles under 70dbs. So a 76dbs noise is close enough (to 80 dbs) that if you had to listen to it for 8 hours you would have hearing loss. It will also be louder than what you hear in your truck going down the hiway. Where as 50-55 dbs is like standing next to several folks talking. If that gives you an idea. The internet threads said they had a few problems with the 1st and 2nd generation of the Boliy. They claim the 3rd generation has fixed those problems. I am starting to see the product offered at some bigger name RV dealerships in my area. |
   Location: Delaware | We were camping last year and I had to walk up to a Honda EUi 3000 (rated 49-58) to make sure it was running. There was a humming like your refrigerator does. This was inside a truck bed. The A/C unit it was running was louder than the generator. We have a 2500 Honda generator (non-inverter) and it rates at 76 and it is as loud as a lawnmower. Big difference. The inverter generators are quiet. Have camped near some onans and they are loud to me. Alot louder than the inverters. |
  Location: El Paso, Texas | Have you ever noticed that people who buy the cheapest loudest generators, ALWAYS run their extension cords to the maxium length (usually towards other peoples camps) and then sit there with their loud generators between the back side of their trailer and the patio side of yours pointing the muffler toward you, and sit there commenting on how quiet their generator is? Boy would I like to shove that generator right up Beep beep beep |
       Location: Northern Utah | And they are the same people who are afraid to run their propane furnace at night, so they leave the Generator running to power their portable ceramic heater. |
 Charter Member
    Location: Holland, Tx | My trailer will not have propane so my water heater and AC will both be on the generator. I think I am going to need something bigger than 3000-3500. The Kipor & Boliy are out because I want electric start. Anyone know anything about Generac? |
 Charter Member
    Location: Holland, Tx | Why is this one so heavy? http://duropower.com/item.asp?PID=155&FID=1&level=0 |
    Location: Decatur, Texas | Because it's not an inverter type. |
| We have a kipor 3500 sinemaster portage generator. We went this way because the generator is not always needed when your at many campgrounds. This way it can be used at home when needed as well. |
  Location: Kansas | We install Generac Generators in our LQ trailers and have been very happy with them. Take a look at their website. We would be more than happy to answer any questions you have about them or to install one for you. http://www.guardiangenerators.com/Products/Recreation/Quietpact/Quietpact.aspx |
   Location: Delaware | The KIPOR has electric start on the 3000. I checked both Honda and Kipor side by side at an RV store. The Kipor was quieter than the Honda (and $800 cheaper). Both the same at idle but when they ran elec heaters the Kipor was quieter. After all this is said I am still leaning towards the Honda because they offer REMOTE start. And, you can tie 2 3000's together if you need more power. |
   Location: Youngstown, OH | Although I have a Generac generator mounted in my hayrack, I have taken notice of the Honda EU models. Someone else mentioned that they had to walk up to the generator before they could tell it was running. I've had the same experience. If if were looking for a portable generator, I would definitely purchase the Honda. I have investigated the Yamaha's as well, and like the HOnda much better. |
 Charter Member
    Location: Holland, Tx | Originally written by Rockinghorserun on 2008-02-04 5:41 AM The KIPOR has electric start on the 3000. I checked both Honda and Kipor side by side at an RV store. The Kipor was quieter than the Honda (and $800 cheaper ). Both the same at idle but when they ran elec heaters the Kipor was quieter. After all this is said I am still leaning towards the Honda because they offer REMOTE start. And, you can tie 2 3000's together if you need more power.  Why not just buy the 6500?? |
   Location: Delaware | The Honda 6500 you were looking at is basically a contractors model. They are heavy and loud. The best ones for camping are the quiet ones (unless you're camping by yourself). And the inverter types are the quietest that Honda makes. When I suggested that you can tie 2 together to get 6000W that would be to run your house if your power went out. The 3000W inverter types are all about 134-140 lbs empty. The 6500 was alot heavier because of the different motor. With these contractor generators you take the chance of burning up the new TV, microwave or anything else that is digital or LED.
Edited by Rockinghorserun 2008-02-04 10:34 AM
 Charter Member
    Location: Holland, Tx | Originally written by Rockinghorserun on 2008-02-04 10:28 AM The Honda 6500 you were looking at is basically a contractors model. They are heavy and loud. The best ones for camping are the quiet ones (unless you're camping by yourself ). And the inverter types are the quietest that Honda makes. When I suggested that you can tie 2 together to get 6000W that would be to run your house if your power went out. The 3000W inverter types are all about 134-140 lbs empty. The 6500 was alot heavier because of the different motor. With these contractor generators you take the chance of burning up the new TV, microwave or anything else that is digital or LED. This is the 6500 I am talking about: http://estore.honda.com/pe/asp/landing_nodealer.asp?RefID=PE&RefModelId=EU6500ISA&ProductSeriesId=P4GG_SUPER&ProductCatId=P2GG |
    Location: Vanzant, Missouri | I have the Honda 3000 generator and it runs my ac unit and elec.hot water heater witout a problem. I place the generator on the back side of the trailer next to the tires and I can't heard it at night...The only time I have ran into problems was trying to run the microwave and AC at the same time. It weighs 147 lbs. On the econo setting it will run about 15hrs on a tank.I'm on a limited budget and I have had it going on 3yrs now and not one problem out of it.....Best money I have spent... |
   Location: Delaware | I was thinking that the Honda 6500 was the Duro you had mentioned in your earlier post. The Honda 6500EUi would do more than you need and be quiet at it for $4000. The Duro 6500 is the contractor's type. Sorry for the confusion. |
