A constant request often posted in this forum is a source of RV parts for the DIYers. There is a continual demand for new and used interior components, for the construction and upgrade of LQs for horse trailers. A new thread suggested the acquisition of damaged trailers, which are in limited supply and not readily available. There are other sources of which I am familiar. Truck and pull behind campers are one. I have, on several occasions owned used truck campers. They are self contained and have most of the same appliances that are common in LQs. This would include an equipped kitchen, bath and shower with holding tanks, hot water heater, furnace, shore and 12v supply with converters/chargers and some have a/c units. I have paid as low as $200 for one and a high of $900. I tallied up the value of the useable parts I could recover from one and it exceeded $3500. Travel trailers are also another source, but there seem to be fewer being set aside than the truck campers. Working used trailers also seem to be more valuable and therefore more expensive. At one time there were many manufacturers of truck campers; this has been drastically reduced to a few now. Everywhere I go, there are unused older campers sitting in yards and fields. The condition of the frame and exterior is not important, it's what it contains and in what condition the components are, that's important. Most of these campers can be had for a nominal price, usually you can have it if you take it away. I literally could obtain a half a dozen this afternoon if I went searching. Most people don't even advertise their sale anymore, because there is little demand. If the cheap wood frame is rotted, a rebuild easily exceeds the value of the unit. Most junk dealers won't be bothered with their removal. On the South Eastern coast and Gulf states, after every major storm, are thousands of damaged boats. Many are damaged beyond an economic repair and are written off by the insurance companies. Most marinas and boat yards have all the repairs they can handle, and as a result, there is a surplus of reconstruction to effect. These boats are then sold for scrap value and no longer are viable to again be used. Many have the same interiors that RV have with one caveat; the interior components are much better built and are of an industrial quality. Marine components are very expensive new. They are built to work in a poor environment of moisture, corrosive salts and temperature extremes. Many land fills will not accept these boats, unless they are greatly reduced in volume by cutting a hull up into much smaller pieces. This is an added expense for a person wishing to rid himself of a worthless hulk. A few calls to some local boat yards and insurance companies would provide another source of parts. The only downside of these sources is getting rid of the shell or hull when it has been stripped of valuable parts. The aluminum skin of the campers can easily be resold without a problem, but in some areas, a fiberglass hull can be considered a hazardous waste. One of the members in our 4H club bought a wrecked motor home for $1200. He stripped the interior of all its components, and then sold the mechanical drive train parts for $2000. He ended up with a nice trailer interior, and with a little work actually made a profit. If you look around and are willing to do a little work, many of these used RV parts can be purchased from several sources. BOL gard |
