F250 Trailer Wiring
burner718
Reg. Dec 2007
Posted 2008-01-17 2:17 PM (#74639)
Subject: F250 Trailer Wiring
I'm trying to use a 6 pin plug for a Featherlite trailer. EVERYTHING works EXCEPT the breakaway battery charger. According to the schematics, there is an orange wire for that purpose in the factory trailer harness. Is that orange switched hot, always hot or ? Anybody got a guess.....could it be a trailer relay under the hood? Like I said, everything else works, I just can't get power to aux./battery charger.
THANKS!!
Posted 2008-01-17 3:07 PM (#74640 - in reply to #74639)
Subject: RE: F250 Trailer Wiring
Have you checked it with the truck running. I think the "hot pin" on the fords is only hot with the switch on. The GM's are hot all the time.
burner718
Reg. Dec 2007
Posted 2008-01-17 4:19 PM (#74643 - in reply to #74639)
Well, I have checked with ignition "on", but without the truck running. There is a relay under the hood, I've replaced it with a known good one with no success. I've also put a tester on the main orange (aux power) wire heading to the back of the truck with no luck....I'll try with engine running. I'm about at my witts end!!
Posted 2008-01-17 5:36 PM (#74649 - in reply to #74639)
My SD Ford only supplies aux power with the truck's ignition on and the engine is running. Any charger hooked to this circuit would charge whenever the engine was running. This type of circuit will not allow the truck batteries being drained by an aux trailer power usage.
burner718
Reg. Dec 2007
Posted 2008-01-17 5:57 PM (#74651 - in reply to #74639)
Copy that....I found a blown maxi fuse.......Does Napa carry those....or Ford only?
Broken Bit
Posted 2008-01-17 8:37 PM (#74663 - in reply to #74639)
Maxi fuses have gotten to be pretty common, should be able to pick one up at any of your local parts stores.  Next question is.... what caused that one to blow?  Better pick up an extra fuse in case the problem is in the truck wireing and it takes ya a while to get it tracked down.  Talk to y'all later...
