Inverters/Generators...???
Mandi/Abby
Reg. Sep 2003
Posted 2008-01-16 3:11 PM (#74563)
Subject: Inverters/Generators...???
Charter Member
Someone had mentioned to get the inverter type generator if I will be running things like my laptop, TV, etc off my generator.
There's a significant price difference in those and the others.
Would something like this work close to or as well as those generators??
http://www.pplmotorhomes.com/parts/rv-converters/tripp-lite-power-i...
If not, what is this particular thing for??
Posted 2008-01-16 3:26 PM (#74564 - in reply to #74563)
Subject: RE: Inverters/Generators...???
Originally written by Mandi/Abby on 2008-01-16 2:11 PM
Someone had mentioned to get the inverter type generator if I will be running things like my laptop, TV, etc off my generator. There's a significant price difference in those and the others. Would something like this work close to or as well as those generators?? http://www.pplmotorhomes.com/parts/rv-converters/tripp-lite-power-i... If not, what is this particular thing for??
Mandy..
Inverters are electronic circuits to alternate the current.
The Tripp-lite is an inverter that runs off a battery.  The pricey inverter generators like the Honda combine an inverter with a DC generator to produce 120 AC power.  The advantage is a quiet slow turning DC generator vs a noisy 3600 rpm alternator/generator like most people have.  The electronic inverters also hold 60 cycles accurately.  A regular generator depends on the engine speed to hold 60 cycles.
Mandi/Abby
Reg. Sep 2003
Posted 2008-01-16 3:36 PM (#74566 - in reply to #74563)
Charter Member
I'm planning on going with an Onan generator...just not the inverter type.
headhunter
Reg. Oct 2004
Posted 2008-01-17 11:44 AM (#74632 - in reply to #74566)
50010010025
What types of appliances are you planning on running off the generator?  I was advised to not plan on running any high end electronics like laptops or TV's off a non-inverter generator.  Since I travel with a laptop for work, I went with an inverter generator.  Yes, they are more money but it sure beats frying your laptop or TV, and the inconvenience factor of losing a relatively low-cost applicance like a microwave wasn't something I was willing to risk either.
headhunter
Reg. Oct 2004
Posted 2008-01-17 11:59 AM (#74633 - in reply to #74563)
50010010025
I looked briefly at getting an inverter to run AC appliances off the trailer batteries, but I'd either have to upgrade to a whole bank of batteries or not plan on running anything off the two standard RV batteries very long.  A generator was the primary solution, but I may look at having solar panels installed at some point.  Had solar panels on a 5th wheel we used to own and they would recharge two RV batteries in a day.   I want and need AC power so the generator made sense for me, but to just keep the batteries recharged solar panels make more sense for some.
