While you are considering your purchase of this trailer, I would carefully inspect the frame, especially under the axles and reward to the back. It is steel and quickly rusts when used in the North East. Also pull the mats and check the condition of the floor, especially the back third. Check the hinge hardware on the drop down windows and the condition of the drop down bars. Check the alignment and hardware on all the other doors. It would be wise to know when the last service was performed on the wheel bearings. The axle capacities are marginal and if not properly maintained, the bearings can quickly fail. The wiring harness behind the plug has had issues, and it would be wise to check the roof structure surrounding the A/C unit, for cracks and flexing I would also pole other owners of Trailets to get their views of ownership Gard  |
