Location: Melbourne, FL | I'm having a heck of a time trying to find the correct tire pressure for my horse trailer tires. It is a "Cato Custom" 6 horse aluminum slant load gooseneck with a small dressing room and two axles (4 tires). It is about 10-15 yrs old. I tried contacting Cato Customs, but they appear to have gone under. I asked Nelson's in Ocala and the guy said they always max out their tires to the PSI stamped on the sidewall - 80 PSI. That sounds high to me since the tires on my dually show 80 PSI max, but Ford says to run 50 in the front and 65 in the rear. Currently, we run 70 PSI, but have had two blowouts of good tires in the last year. Any input would be appreciated. Tom |
      Location: Rocky Mount N.C. | That big of a trailer, assuming it has load range E tires then I would run the maximum pressure that's stamped on the tire( example: 235-85R-16 lrE, inflate to 80 psi) If your tires are older than 5 years old, then I suggest that you replace them, they may not be worn out but they have been exposed to 5 years of "the elements," (Florida sun) and are deteriorating. Soon to blow out when you least expect it!! Cato Classic Horse Trailers, over at Hernando, Fl. closed it's doors a couple years ago.
Edited by retento 2007-12-05 10:56 AM
       Location: western PA | To get the highest load factor and the coolest running on a loaded tire, use the numbers found on each tire's sidewall. Each manufacturer will rate his tire based on his testing and experiences. The same sized tire made by different manufacturers will result in different load ratings. The inflation numbers stamped on a truck's data plate, is an average figure that will result in an acceptable ride and loading factor. The Explorer/Firestone debacle is an example where ride was considered over the load, and the tires were run underinflated with the resulting accidents. This number will not result in the highest load factor a truck will handle. If you are constantly having blow outs, you should consider trying to figure out a pattern. Some questions would include: Are the failures always on the same side of the trailer or random? Do they fail when the trailer is loaded or empty or both? Are your tire pressures constantly monitored? What speed were you traveling when they failed? Have you replaced the damaged tires with the same brand? When they failed, did you have a dealer try to determine a cause? I would first try to determine where on the trailer they were located. If it's in the same spot, there can be several reasons; axle alignment, loading, brake problems even a wheel bearing or the trailer's attitude when loaded. If it's one side, the passenger or driver's, it may be a driving problem dropping the tires off the edge of the road etc. If it is completely random, I would suspect the tires and consider changing brands. There are many good brands of tires and a few bad ones. A search through these postings will give you many ideas about which are most favoured and which are scorned. BOL Gard
Edited by gard 2007-12-05 11:11 AM
  Location: KY | gard is right always run your trailer tires at the max psi cold printed on the sidewall. When it says cold it means that is what the tire has in it when the tire is cold. To insure you are checking the tires when they are cold check them before you pull the trailer or at a gas station allow the tires time to cool down. The difference between your truck tires and a true trailer rated tire is the trailer tire has a much stiffer sidewall. Basically run what the door says on your truck in your truck tires and run the max psi cold printed on the sidewall in your trailer tires. Like gard said if you still blow tires start using the process of elemination to determine if it is the trailer or the tires. If it is the tires try another brand and you may want to try a tire with a higher load rating.
Edited by dixie 2007-12-05 11:10 AM
     Location: sc | Originally written by gard on 2007-12-05 10:58 AM To get the highest load factor and the coolest running on a loaded tire, use the numbers found on each tire's sidewall. Each manufacturer will rate his tire based on his testing and experiences. The same sized tire made by different manufacturers will result in different load ratings. The inflation numbers stamped on a truck's data plate, is an average figure that will result in an acceptable ride and loading factor. The Explorer/Firestone debacle is an example where ride was considered over the load, and the tires were run underinflated with the resulting accidents. This number will not result in the highest load factor a truck will handle. Tire size/load/inflation ratings are set by the "industry", not the manfacturers. The ratings should be the same for a given tire size no matter the manufacturer. The inflation numbers on the data plate are what is necessary to meet the axle ratings.....generally have nothing to do with ride. IF you are under the axle rating then you COULD run less psi. I sure dont run the 80psi in the rear of my truck empty, ruins the center of the tire not to mention lack of traction. Some 3/4 ton+ trucks have loaded/empty ratings, but they are few and far between. I dont remember seeing an actual conclusion to the Explorer/Firestone thing, mostly just finger pointing............ |
     Location: sc | Originally written by tgillesp on 2007-12-05 11:14 AM I'm having a heck of a time trying to find the correct tire pressure for my horse trailer tires. It is a "Cato Custom" 6 horse aluminum slant load gooseneck with a small dressing room and two axles (4 tires). It is about 10-15 yrs old. I tried contacting Cato Customs, but they appear to have gone under. I asked Nelson's in Ocala and the guy said they always max out their tires to the PSI stamped on the sidewall - 80 PSI. That sounds high to me since the tires on my dually show 80 PSI max, but Ford says to run 50 in the front and 65 in the rear. Currently, we run 70 PSI, but have had two blowouts of good tires in the last year. Any input would be appreciated. Tom What size tires? What does it weigh? How fast do you drive? If youre haveing blowouts at 70, 80 probably wont make much difference. |
      Location: Texas | Run it at max pressure as stated before. Truck tires can be run lower but they also don't get pulled sideways as much as trailer tires do, you don't want a soft tire when you make a sharp turn. |
       Location: western PA | What happens to a soft tire on the front of a truck when you go around a corner? Gard |
       Location: western PA | Originally written by chadsalt on 2007-12-05 3:36 PM Tire size/load/inflation ratings are set by the "industry", not the manfacturers. The ratings should be the same for a given tire size no matter the manufacturer. Chadsalt: I just inspected some of the tires I use. Four different sets and manufacturers all 265/75/16 "E" range . Each manufacturer had a different load rating at a maximum pressure of 80 psi. The range in load carrying capacity was over #400 from the least to the most. Gard |
     Location: sc | Originally written by gard on 2007-12-05 8:51 PM Originally written by chadsalt on 2007-12-05 3:36 PM Tire size/load/inflation ratings are set by the "industry", not the manfacturers. The ratings should be the same for a given tire size no matter the manufacturer. Chadsalt: I just inspected some of the tires I use. Four different sets and manufacturers all 265/75/16 "E" range . Each manufacturer had a different load rating at a maximum pressure of 80 psi. The range in load carrying capacity was over #400 from the least to the most. Gard Notice I said "should". My spare - spare is a Chinese job, has some off the wall load spec and is missing some DOT markings. |
Originally written by chadsalt on 2007-12-05 3:36 PM Tire size/load/inflation ratings are set by the "industry", not the manfacturers. ?????? Gard Edited by gard 2007-12-06 8:27 AM
      Location: Texas | Originally written by gard on 2007-12-05 6:44 PM
Hopefully a soft tire on a truck isn't getting dragged sideways like trailer tires do.
       Location: western PA | Just making a point. Did you ever look at the profile of a radial tire on a vehicle going around a corner? If it's a hard corner, the front tire is almost an "L" shape. BOL Gard |
        Location: Vermont | Originally written by tgillesp on 2007-12-05 10:14 AM I'm having a heck of a time trying to find the correct tire pressure for my horse trailer tires. It is a "Cato Custom" 6 horse aluminum slant load gooseneck with a small dressing room and two axles (4 tires). It is about 10-15 yrs old. I tried contacting Cato Customs, but they appear to have gone under. I asked Nelson's in Ocala and the guy said they always max out their tires to the PSI stamped on the sidewall - 80 PSI. That sounds high to me since the tires on my dually show 80 PSI max, but Ford says to run 50 in the front and 65 in the rear. Currently, we run 70 PSI, but have had two blowouts of good tires in the last year. Any input would be appreciated. Tom Gee...This is NOT the same FORD MOTORS that told all of the Explorer owners to run under pressured tires is it???... |
       Location: western PA | Paul Are you insinuating that 27psi isn't enough for a 4500# vehicle? What about comfort and a smooth ride? Isn't that important? Gard |
      Location: Texas | Originally written by gard on 2007-12-06 10:03 AM
Yep, I understand what you're saying. I was just saying it's easier to break the bead loose on a soft trailer tire than one that's at max pressure when you're making one of those really tight turns where the trailer tires actually drag sideways. Ideally I never want to make a turn like that but there are a lot of places where you don't have any choice. |
       Location: western PA | I agree, other than overloading a tire, about the worse thing you can do to it is run it underinflated. BOL Gard |
 Location: Alabama | Question...I am leaving out for a horse show tomorrow and got hubby to check tire pressure on truck and trailer. All were low on air. PSI is 80 on truck and trailer tires. He inflated them all to 75 and said that what it should be...why? I guess because he says so. He argues that if I inflate them to 80 PSI then load the horses on there, they will be overinflated. Am I going to be ok traveling on 75 PSI when sidewalls clearly say 80?? |
       Location: western PA | Unless you have an extremely heavy trailer and need every pound of carrying capacity, a five pound difference in air pressure won't be an issue. The trailer tires should be run at a max rated inflation for the best load factor. If a tire is inflated to 80 psi, it will not matter what load is placed on it, the air pressure will not increase. It will only increase with temperature and that is why tires are checked for a cold inflation rate. The increase due to thermal expansion is considered by the manufacturer when he posts the pressures. That is why you should not let air out of a warm tire. BOL Gard
Edited by gard 2007-12-07 5:46 PM
Location: Chardon ohio 44024 | YOU CAN GO TO THE TIRE AND RIM ASSOCIATION INC @US-TRA.ORG THEY HAVE A GOOG TIRE INFLATION CHART THAT GIVE YOU YOUR TIRE PRESSURES FOR THE LOAD OF YOU TRAILER IF YOUR TAILER IS AT 14000 80 PSI WILL WORK AT 80PSI ONE TIRE CAN HAVE THE LOD OF 3420 LBS |
Location: Melbourne, FL | Thanks Dales. That 3420 number - is that for a load range 'E' tire? I didn't see any chart on us-tra.org, just info on how to buy their $80 book of tire standards. Thanks, Tom |
      Location: Rocky Mount N.C. | "MOST", LT235/85R16lr-E tires are rated at 3042#, single load at 80 psi. A Goodyear LT235/85R16lr-G, G614 RTS is rated at 3750#, single load at 110 psi. If the tires are run as duals the load rating is less, its stamped on the tire. I don't pay much attention what's on the sticker inside the drivers door. I go by the info that's stamped on the tire and the rim. No matter what the maximum pressure is stamped on the tire, do not exceed the maximum rated pressure of the rim!! The tire is no better than the rim it's mounted on, they pretty much got to match. |
Location: Chardon ohio 44024 | YES THAT WAS FOR E RATED TIRE |
        Location: North Carolina | Getting back to the original question ... Inflate your trailer tires to the maximum cold pressure stamped on the tire. AND keep it maintained... Why?? You'll get the maximum load capacity, best fuel use, less wear, and most security from tire failure or rim pull-off. Who says ... Carlisle, designer and maker of many trailer tires. see here >>> Carlisle recommends max pressure at all times. see page 7 of this link >> http://www.carlisletire.com/product_care/proper_tire_care_safety.pdf Tires on the tow vehicle have to perform differently than trailer tires. I follow the truck builders recommendations for tire pressures. |
     Location: sc | Originally written by hosspuller on 2007-12-11 10:21 AM Getting back to the original question ... Inflate your trailer tires to the maximum cold pressure stamped on the tire. AND keep it maintained... Why?? You'll get the maximum load capacity, best fuel use, less wear, and most security from tire failure or rim pull-off. Who says ... Carlisle, designer and maker of many trailer tires. see here >>> Carlisle recommends max pressure at all times. see page 7 of this link >> http://www.carlisletire.com/product_care/proper_tire_care_safety.pdf Tires on the tow vehicle have to perform differently than trailer tires. I follow the truck builders recommendations for tire pressures. Not that I disagree with max pressure in trailer tires.........BUT Carlisle also says not to exceed 60 mph. Apparently Carlisle makes an inferior grade product, not defective as in blow outs, but inferior as the "industry standard" for ST tires is 65 mph. So I take that into account when considering the rest of their "advice" |
        Location: North Carolina | Originally written by chadsalt on 2007-12-11 10:30 AM Not that I disagree with max pressure in trailer tires.........BUT Carlisle also says not to exceed 60 mph. Apparently Carlisle makes an inferior grade product, not defective as in blow outs, but inferior as the "industry standard" for ST tires is 65 mph. So I take that into account when considering the rest of their "advice" Chadsalt ... By your last post, I surmise, you think good logical advice is tainted by its source. You can choose your opinion based on your belief. But unless you're fooling yourself, facts are not to be selected. Anyway ... I hope you trust this source better. http://www.goodyear.com/rv/weighing/weigh_trailer.html |
     Location: sc | Originally written by hosspuller on 2007-12-11 1:58 PM Originally written by chadsalt on 2007-12-11 10:30 AM Not that I disagree with max pressure in trailer tires.........BUT Carlisle also says not to exceed 60 mph. Apparently Carlisle makes an inferior grade product, not defective as in blow outs, but inferior as the "industry standard" for ST tires is 65 mph. So I take that into account when considering the rest of their "advice" Chadsalt ... By your last post, I surmise, you think good logical advice is tainted by its source. You can choose your opinion based on your belief. But unless you're fooling yourself, facts are not to be selected. Anyway ... I hope you trust this source better. http://www.goodyear.com/rv/weighing/weigh_trailer.html Thank you for the link, but my tire knowledge wasnt in question (nor was I questioning yours). I tend to take the whole picture into account. Personally I wouldnt quote Carlisle for ANY type of tire related info. The link for Goodyear (a much better choice IMO) displays exactly what Im talking about. People typically assume max psi is the only answer...hard to go wrong with max psi, but it is not the only answer. Case in point, a lady I know purchased a Calico 2H BP, 12' x 6' on the floor, GVWR 7000#. That trailer came with ST235/80/16 tires, 80psi. Loaded with horses I doubt that trailer weights 5000#. At 80 psi that trailer is one SOB (and probably dangerous as I doubt it ever has more than one tire on the ground) to pull down a bumpy road, loaded isnt much better. I dont know what psi she ended up at, but 80 psi certainly wasnt right. Saleman told her a 16" tire would be "better". That size tire was a horrible mismatch for that trailer, bigger/max is not always better. |
