| I sold my C&C and now looking for its replacement ( if there is such a thing - sigh) This weekend we went to look at a 2001 Sundowner 3H with 8 SW. The trailer was pristine inside and out except for when we looked underneath the frame just seemed to be disintegrating. You could peel away layers of rust with your fingers. Before we went to look at this particular Sundowner we called the company and asked about the construction of this 2001 model, they said it was all aluminum - so what does that mean? That whoever answered the phone made a mistake? Anyway we passed on the trailer. |
      Location: East Tennessee, USA, Planet Earth | Do you think it was the undercoating that was peeling??? |
      Location: Rocky Mount N.C. | Jennifer..... What is the model number? Do you remember if the trailer had a double stripe of red and white reflective tape around the bottom or was it a single red and white stripe? Got any pictures to post? What state is this trailer located? Lot of salt on the roads in the winter? AND...Why did you sell your C&C?!!! |
       Location: western PA | You will have to conclude if the frame is aluminum or steel and if it was covered with any coatings before you can determine any damage. It will take a close examination with a pocket knife, by scraping a small area of the surface and examining the exposed metal, whether it is steel or aluminum. Any kind of coating can hide many flaws. Before I would consider a purchase of this trailer, I would ask that the frame be pressure washed and inspected. If you have any reservations at all, or the seller is not cooperative, walk away and don't look back. There are many good trailers available now, and the purchase of one with a questionable frame is not economically realistic. BOL Gard |
| Sold the C&C because the 11 ft SW was just way too much to haul, and wanted to downsize. This trailer had one strip of DOT reflective tape. Gard we passed on it due to the extreme amount of corrosion on the frame. The coating was peeling off and then you could pick away the rust with your fingers. Didn't need a knife. And curiously, it was the frame that runs the long way of the trailer that was so corroded, on both sides. The cross pieces of the framing were fine. I was just curious what "all aluminum" frame means. |
      Location: Rocky Mount N.C. | All aluminum frame trailers will have a short steel frame that the axles are mounted to, and then this short frame is mounted to the aluminum box or aluminum frame work of the trailer. There is some steel in the area of the hitch. Steel frame-aluminum trailers will have a steel frame or chassis that runs the entire length of the trailer and the aluminum box is mounted to this steel frame. The steel frame trailers tend to be stronger, but are much heaver than the all aluminum trailers. The "Sundowner" trailers can be reconized at a glance by the red and white DOT tape. A double row or stripe is all aluminum, single row or stripe is the steel frame trailer. Hope this helps, I'm not very good at "splain'in" things............sometimes!
Edited by retento 2007-12-03 12:50 PM
    Location: Western WA | The easiest way to determine if a trailer has a steel or aluminum frame is with a magnet. If it sticks, its steel. If it doesn't, its aluminum. |
       Location: western PA | Jennifer Aluminum corrosion is not what you described. It is not found in sheets and doesn't peel off. That's why I suspect that it was a coated steel frame. Aluminum corrosion (oxidation) is white or grayish, and can be discoloured with black or brown areas. It will crumble to the touch if the entire metal thickness is effected, or a smaller spot will slough off like chalk. It will also be brittle, easily breaking by impact or bending. Corrosion can only be stopped by a chemical process and the damaged area, if large enough will have to be replaced. On aluminum, this is an expensive process. You were wise to decide to buy elsewhere. By doing your homework and looking at the structure, you saw past the pretty parts and discovered it's real condition. Good job! Most people shop for trailers by the colour of the microwave or curtains. As you have seen, brand names mean little with used equipment. There are good trailers and bad ones of every brand. Spending a little extra time looking underneath will determine if you have a bargain or a long term headache. BOL Gard |
Edited by PaulChristenson 2007-12-03 6:23 PM
Location: Chardon ohio 44024 | IF YOU WOULD LIKE TO SEE SOME PICTURES OF SUNDOWNER STEEL FRAMES THAT HAVE ROTTED OUT E-MAIL ME AT dales7779@aol.com I have alot of photos of sundowner rotted out frames. |
      Location: East Tennessee, USA, Planet Earth | can you please post a link to those photos? |
| The seller of that trailer should have recognized the issue and there was no reason why someone didn't claim it on the 8 year structural Warranty.....it could have all been replaced....it sounds like it was caused from lack of care.....the suncoating will do that in time when a trailer is parked in damp areas or in a field with taller grass I have noticed.......but under the suncoat is a powder coated steel frame .....but Sundowner will stand by their warranty and pay to replace the entire frame if necessary.....I have seen it. |
   Location: Midwest USA | THANK YOU KMARTIN.....Posting pictures of a certain manufactures issues is really not needed......I like Kmartins comment....it boils down to certain individuals maintainance on their trailer...if you don't change the oil in your truck what happens ???....PROBLEMS!!!!!....WELL, we all know you have to maintain your trailer also.....yeah there are some frame rails out there with problems, BUT..Sundowner backs their product better than if not just as good as anyone else in this industry.....Everyone wants to slam Sundowner every chance they get..........how bout slamming *#%ss for their skinning on the S*&#$ models....how bout slamming JOE BLOW on the rough edges on all the welds in the stall area and manger doors....does it matter???...yes it does to an extent..I know Sundowner has replaced ALOT of frame rails under warranty...standing behind the product.......I see posts on here everyday about people and their problems which is good...dealers step up and offer help....I am sure, if the owner of the trailer would have contacted a dealer or the factory the warranty issue would have been taken care of.......How can a company be in business for 30 years and not take care of their product ????....just not possible......SO, in the future remember, if you don't ask for help, then how can anyone know you need help !!!! |
      Location: East Tennessee, USA, Planet Earth | I agree with Kim that Sundowner does back up their products. I am very pleased with my trailer and the company. |
   Location: Southern Indiana | Just a few questions after reading 3 yearhitch's commentsThis thread was asking information about corroded side rails on a horsetrailer right?3 year mentioned the possible lack of maintenance on the seller's part.My question is-- How and What maintenance is a trailer owner supposed to do regarding the side rails or the underneath side of any horsetrailer? I service my brakes, drums and axles yearly. I take the mats out of the horse compartment bi annually and powerwash..........Is this very anal retentive trailer owner missing a maintenance item? Horsetrailerworld threads are the best information on the web!! It is amazing the wealth of information availabe on so many subjects!! |
       Location: western PA | Coltafflyjo, it sounds as if your maintenance has been very complete and you should be enjoying a reliable and good looking trailer. The only additional item I might recommend is an occasional rinsing of the bottom of your trailer. This will clean off the road salts and urine that seeps through your floorboards. This can be easily accomplished with a garden hose and lawn sprinkler. A steel frame that is powder coated and then sprayed with an undercoating should not rust out in a few years. We live in the rust belt of the north east and recently sold a steel trailer that we bought new in 1992. There were no rust issues that affected its structural integrity. Aluminum frames are not immune to problems and are not maintenance free. It is wise to spend some time looking under your trailer. You can see if there are any problems and anticipate any maintenance before they become a repair. Small rust or corroded spots can be touched up before they require some major attention. BOL Gard
Edited by gard 2007-12-06 9:33 AM
   Location: Midwest USA | Colt....I believe Gard pretty much summed it up....It is kinda like the old addage.."out of site--out of mind"....Not alot of people think about getting under their trailer and pressure washing it good at sometime or another...Have you ever gone to a car wash and bought the "works" ??...Well with the "works" you get an under spray....and what does this under spray do ???..it sprays away all the road grim and salt (if you live in a region with snow) from under the vehicle. Why do you think they offer that??..Cause you need to do it every once in a while...Amazing isn't it !!!!.The concept of steel and undercoating has been going on in the automotive industry for years...What makes a horse trailer any different???..They are both investments, so why not take care of and protect that investment !!!....Thanks Colt and Thanks Gard.... |
   Location: Midwest USA | Dale....after reading your profile, I now know why you posted what you did..... If you want to get into a finger pointing match, then game on.....because with the lines that you carry, I would win everytime but the thread would be shut down real quick by Dave and I am not going to go there... Sundowner versus Exiss...Let's start that thread and see what comes about....floors,welds,skin,warranty,doors,etc,etc.........LOL !!!!...Sundowner versus UTC....that would be another good thread....but we will not go there......;)..Happy trails !!! |
       Location: western PA | Perhaps we all should take a deep breath and start over |
Location: Chardon ohio 44024 | Hay did not say that sundower was a bad trailer i just have had sundowers in and the photo were for sundower to look at and two of the trailers did git reaird by sundower. I was just looking to help not to put down sundowner trailers. |
   Location: Southern Indiana | Hey 3 year hitch to bumper-- I spray my undercarriage the redneck way--I just drive the trailer when the roads are wet when it rains........It even cleans the horses too!!! Thanks Gard for the info--I just did not want to overlook anything!! |
