     Location: Central Arkansas | I have had Camping World do new installs in LQ trailers that did not come from the conversion company with the rooftop satelite. I have also had Camping World upgrade older crank up satelites with the dome style. They do a good job and have the best prices. I like their flat install rate. That way you know exactly what it is going to cost BEFORE they do it. I do recommend having the trailer wired for an outside satelite or cable source at the same time. That way, if you are parked under a tree or have a building blocking your signal, you can hook a portable dish up to get it. |
