  Location: Grand Rapids, OH | Hey all - My husband and I have learned alot from these forums and obsessively look at this site for trailers! We are interested in a 3H w' 10ft LQ. However, it does not have an electric jack. How simple is it to add one? What is the approx cost? Also, from reading some other posts I think we may need a new truck! We currently have a 2005 F250 crew cab 4x4 diesel short bed. Will this pull the trailer? The ford website doesn't really give any good info on trucks other then 2008. The trailer is all aluminum and 8' wide. Is a tapered nose flat of "V" shaped? Sorry to sound like an idiot, we just want to make the right choice. Thanks! |
   Location: East Central Kansas | Here you go on cost. http://www.southwestwheel.com/store/c-93-powered-drive.aspx You should not have any trouble installing this. Hooking into the electric should be a little challenge, however the instructions should guide you. I had an electric jack on one trailer and did not have any problems with it. I have a hydraulic jack now and like it better. |
   Location: Odenville, Alabama | "Tapered" usually means "V" Shaped. I pulled an 8'wide 3 horse with 12' LQ for years with a 2500HD crew cab/short bed. It was fine, but I opted to buy a 3500 crew cab dually just so I'd have more stability in the rear end with the extra wheels. Makes a world of difference. No electric jack on a 10' LQ? Yeah, it would be worth it to install one. They'll run around $1K installed. My batteries went dead and I had to crank mine up and down by hand, it was really hard! |
| It may cost more,but I think you will be more pleased if you install a hydralic jack rather than electric. |
  Location: Grand Rapids, OH | Thanks for the replies!Ok...another dumb ?; what is the difference between electric & hydraulic? How much to install the hydraulic? We had a crank w/ our 6' LQ and hubby said no more! |
        Location: Vermont | Use one of this website's sponsors... They have electric and hydraulic!!! http://magnumliftsystems.com/
Edited by PaulChristenson 2007-09-05 5:37 PM
| I think that the hydralic jacks are smoother,and faster when lifting or lowering a bigger trailer. |
       Location: Northern Utah | Absolutely they are faster. The 2006 F250 CC Shortbed Diesel/auto was rated as follows 3.73 axle = GCWR of 23,000lbs 4x2 15,900lbs max trailer, Max payload in bed = 3000lbs 4x4 15,500lbs max trailer, Max payload in bed = 2800lbs I don't think the 2005 were much different.
Edited by Painted Horse 2007-09-05 6:56 PM
   Location: Odenville, Alabama | Our new trailer has hydraulic jacks. Faster, smoother and quieter. They are more expensive though. No electric motor to burn out either!! |
    Location: THE GREAT NORTHWET, OREGON(THE REAL GODS COUNTRY) | My trailer has hydraulic and it is operated by electric pump.I am darn glad I dont have to do this one by hand! At around 4800 + pounds on the ball, it would be a Killer. |
  Location: Claxton, Ga. | Originally written by SLICKRNSNOT on 2007-09-05 11:40 PM My trailer has hydraulic and it is operated by electric pump.I am darn glad I dont have to do this one by hand! At around 4800 + pounds on the ball, it would be a Killer. Amen to that one. No more cranking allowed. Just hit the up or down button. Worth every penny it cost. |
   Location: Coconut Creek, FL | Nother believer in the hydraulic jack - MUCH faster. mine was installed afterwards as is usually the case |
  Location: Grand Rapids, OH | Do you mind me askingapprox how much you paid? Thanks! |
  Location: Northwest Ohio | Welcome to the forum Reddun25! I have a question too. We have 3H 12' LQ with power jack and stabilizers, but I don't know the difference between electric and hydraulic either. We don't have to be plugged in to work them. How do I know what ours are? |
   Location: Coconut Creek, FL | The original owner of the trailer had it installed and I bought it from her, so I don't know. just glad she did! |
      Location: Rocky Mount N.C. | I'm still twisting and cranking all 33' of mine by hand......Ya want to wrestle, LOL!!! Next trailer will be hydraulic, don't care if it's a 10' long bumper pull.......It WILL be hydraulic! |
   Location: Burleson, TX | One of our boarders has an electric jack on her two horse, no dressing room bumper pull. Even that is wonderful. |
      Location: La Cygne, KS | Hydraulic is the way to go from an anti-theft perspective too. If you install the kind that takes a key before raising and lowering, it helps deter someone from quickly changing out the coupler(if you only have a coupler lock on) and lowering that trailer down fast on to their truck. I lowered my gravel drive to make the trailer sit lower, so it has to be raised a bunch to get under a truck and also use coupler bolt lock along with the coupler lock. Love our Hydraulic compared to the electric one we used to have. Much quieter and faster to use. |
 Location: Oz land | ok guys - it has been asked here twice -WHAT IS THE DIFFERENCE BETWEEN HYDRAULIC, AND AN ELECTRIC JACK? i DON'T KNOW EITHER. I hit up and it raises up. what is the difference. Thanks Never mind - I went to the website - and read. I have electric.
Edited by dinero01 2007-09-06 2:12 PM
  Location: Grand Rapids, OH | Are you happy with the electric? I wonder if it matters on the size of the trailer? |
 Location: Oz land | Reddun - I answered your question on the trailer post about Sidekick trailers too. This has an electric jack on it. My first one - so I really don't know any different. Now, the only is, when you batteries die, which mine did, you simply can't unhook, and no I wasn't going to hand crank it off - I went and bought new batteries for the trailer. I just like not having to do physical labor of hooking on and off. |
 Location: Pennsylvania | Years ago I had a 2H bp with electric jack. I thought it was great (and it was) until the day I ran into a problem and it would not go up. Took 3 hours to locate the trouble and get it working again. Meanwhile, I could easily use the manual jack, however I did not have any way of getting the electric jack up - not until 3 hours passed and we found the trouble. This was the only electric jack I ever had, and apparently there was not a back up plan if it stopped working. I would love to have one on my 3H GN, but if I do I want to be sure that if it quits working for whatever reason I can somehow get it "out of the way" and use my manual until it is fixed. |
  Location: Grand Rapids, OH | Goodto know...I am thinking I will lean towards a hydraulic as long as it doesn't break the bank...that is what my horses are for! Wait....this IS for the horses! |
   Location: Arkansas | the electric jack we have is connected through the 2 speed gearbox. When it had an issue, we were able to easily crank it up (lifting the 2 jacks) by hand. Many turns, but easy and it worked perfectly. BTW, got it fixed cheaply once diagnosed and never another problem, but nice to know we can get the jacks up and travel. |
        Location: Vermont | Just out of curiosity...on the average, how much dead weight is added to a trailer when a hydraulic jack complex is added to the trailer? |
