Towlite trailer electrical plug issues...HELP!!!!
mrstacticalmedic
Reg. Dec 2005
Posted 2007-08-26 12:00 PM (#66477)
Subject: Towlite trailer electrical plug issues...HELP!!!!
Ok you guys have been wonderful in helping me in the past...so I need your expertise again.
Originally this trailer had a 6pin round plug.  I had to take it in and get it converted to a 7 pin round.  Well as I was towing it in the back yard the plug came out and pulled off leaving the wires hanging.
I have tried for 5 hours to put the wires back together on the correct pins.
Of course it is Sunday and nobody is open today, and I have to go to work today (pony rider at a track and a TB farm).  I am supposed to pony some young 2 yr olds at the farm today.
So if anyone has had any luck converting a towlite 6pin to a 7 pin round I could use your help..  my wires are black, red, green, brown, yellow, and blue.
thanks a bunch in advance!
crowleysridgegirl
Reg. Apr 2005
Posted 2007-08-26 12:47 PM (#66479 - in reply to #66477)
Subject: RE: Towlite trailer electrical plug issues...HELP!!!!
2000500100
I don't know if he is available,but you might try PM'ing Hosspuller,he has told us a lot of stuff about electrical wiring on trailers in the past.
chadsalt
Posted 2007-08-26 1:00 PM (#66483 - in reply to #66477)
1000100100100100
look here,  http://www.horsetrailerworld.com/home/wiring.asp
i would start by matching color to color on the the yellow, green, brown, blue. as for your black and red, one should be 12v and the other the ground.  can you follow one of them and see if it grounds on your trailer?  i would have to guess the red is the  12v and the black is the ground?????
mrstacticalmedic
Reg. Dec 2005
Posted 2007-08-26 1:01 PM (#66484 - in reply to #66477)
Thank you!  I do have a guy who has done wiring for me in the past coming over.  I am hoping he can get it fixed for me.  If not I will definitely PM hosspuller.
Posted 2007-08-26 1:01 PM (#66485 - in reply to #66479)
CRG .. Thank you for the note... but this site has a pretty good resource.
try the 7 pin diagram at this link... http://www.horsetrailerworld.com/home/wiring.asp
Be aware that the brake and 12 volt power positions are interchanged in some vehicles.  If your trailer brakes are always locked up, switch the two wires in the trailer plug.
Once you get the wires sorted out, make a little note in your truck's manual.  Then if you're in the same pickle jar again, you have the means to fix it quickly.
Terri
Posted 2007-08-26 1:12 PM (#66488 - in reply to #66485)
200050010010010025
This is a good Idea and I'm glad I've done it.  That way when you stop for snacks and the stupid little brat from the next car decides to climb into your truck and pulls all the wires out of your trailer junction box you will know how to put them back together.
BigT
Posted 2007-08-26 3:05 PM (#66493 - in reply to #66477)
If you are using a 7 flat pin RV plug it is color coded different than a 6 pole horse trailer plug.
The typical wiring for a 6-way round is  Blue...brakes   Black...Ground   Brown...taillights  Green...right turn  Yellow.. left turn Red... accessory
A 7-pole RV connector is different.   White...ground  Blue...brakes  Green...taillights  Black...battery  Red...left turn  Brown...Right turn  Yellow... Auxilary
Terri
Posted 2007-08-27 11:09 AM (#66539 - in reply to #66493)
200050010010010025
Just to show the difference between trailers, my featherlite came with blue as the accessory, white as the ground and black as the brakes.
